[Armbian build PR] - sm8250 devices improve: use losetup and fix qbootctl
Description
  • Ubuntu noble ships qbootctl with a bug which makes qbootctl service can't start: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1057918. I fixed it in my ppa liujianfeng1994/qcom-mainline.
  • I use a silly dd method to create rootfs. It's better to use losetup to load the built image and copy rootfs from the mounted loop device.
Note: ubuntu noble also ships mkbootimg with bug: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1050300, which will make this extension not working. So it's better not using noble as build environment. Debian's fix is still not packaged: https://salsa.debian.org/android-tools-team/android-platform-tools/-/commit/d26c3b5ac89efd92eb96ad029cd06400c1c9f015
How Has This Been Tested?
  • [x] ./compile.sh BOARD=xiaomi-elish BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DEB_COMPRESS=xz DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=noble
Checklist:
Please delete options that are not relevant.
View the full article
