I guess this is hardware-independent, so I post here. Looking for ways to disable IPv6 I found 3 ways to achieve this on Linux, none of them really working for armbian debian build.
1. /etc/sysctl.conf:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
this disables the network interfaces to use IPv6, not IPv6 itself. This method is also known to cause trouble e.g with X-Forwarding via SSH and Postfix server.
netstat still lists IPv6 entries
2.  /etc/default/grub (GRUB tells the kernel not to load IPv6)
This does not exist in armbian, I guess it is simply not using GRUB
3. /etc/modprobe.d/aliases
change
alias net-pf-10 ipv6
to
alias net-pf-10 off
Some people suggest to additionally add
alias ipv6 off
I'm not so sure what this is actually doing. It does probably set an alias so that some other instance that starts net-pf-10 does not start ipv6 but instead "off" which is not defined so nothing is started?!
However this file does not exist in armbian as well
So how can I disable IPv6 on armbian?
