Hi everybody, I recently purchased a Orange Pi Zero since I needed a tiny board, and after setting it up I noticed that the resolution didn't fit properly in a portable TV I was using. Doing some research (I'm a complete newbie), I found the command "h3disp" ot change resolution on Armbian for H2+ and H3 boards, so I gave it a try. Now it's completely black and no signal on AV IN.
Thanks to a post in this site, I noticed that every command in h3disp was for HDMI outputs and that doesn't fit Orange Pi Zero since it supports PAL and NTSC only, so now after changing between 480i and 576i doesn't seem to be showing anything at all.
I was wondering if I could restore the resolution to the default settings, like if I "never patched" the resolution file. I'm using a RCA cable with some jumpers soldered on it.
Thank you so much in advance!
