Aiden Posted June 10 Share Posted June 10 (edited) Hello all's, after several tries, I have functional path how to install latest Armbian with functional Wifi (perfectly work) and Ethernet (semi-functional (slow speed) to emmc, on Hannspree 80-AK000001G002 Android TV Box (RK3288). !!! Use at your own risk !!! Download Multitool https://users.armbian.com/jock/rk3318/multitool.img.xz Create SD card with Multitool using balenaEtcher https://etcher.balena.io/#download-etcher Download old Armbian image (Armbian_21.05.0-trunk_Rk3288_focal_current_5.10.27.img.xz) from balbes150 https://mega.nz/folder/j9QSDQSQ#6WpasOlbZYIInfw6yo4phQ/file/Sw5nHADY Put image onto SD card, into images folder Put SD card into tvbox, without attached HDMI cable Power on tvbox Wait for blue led blinking, after that connect HDMI cable Create backup (for your own safety) Erase flash Burn downloaded old Armbian image into flash Shutdown Power on tvbox and complete initial setting (its important for emmc resize) Power off tvbox Download or compile (I prefered compile it own) latest Armbian image for Thinkerboard (be careful, must be Thinkerboard with RK3288, not Thinkerboard-2 !!!!) Create SD card with Thinkerboard image (my recommendation is use another SD card) Insert SD card into tvbox Power on tvbox Wait for boot complete Complete initial settings Using lsblk identify correct device address for emmc storage (in my case its mmcblk2p1) Create mount path: sudo mkdir /tmp/emmc Mount emmc into it: sudo mount /dev/mmcblk2p1 /mnt/emmc Paste Thinkerboard files into emmc using rsync: sudo rsync -avx --exclude=/mnt/emmc / /mnt/emmc Power off tvbox Eject SD card Power on tvbox Edited June 10 by Aiden 0 Quote Link to comment Share on other sites More sharing options...
