RSS Bot Posted June 11, 2024 Posted June 11, 2024 Description Bump sm8250 current to 6.9 based on postmarketos's branch: https://gitlab.com/sm8250-mainline/linux/-/tree/sm8250/v6.9?ref_type=heads. Panel and touch screen patches from 6.7 are dropped because they are never enabled in kernel config. In 6.9 bluetooth of qca6390 won't work with default address hardcoded in driver, and setting a new address of bluetooth can make it work again, so I add a service to generate bluetooth address based on /etc/machine-id, How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] ./compile.sh kernel BOARD=xiaomi-elish BRANCH=current DEB_COMPRESS=xz [x] Tested with xiaomi-elish, panel, gpu, vpu, sound works. Note: noble gnome's pipewire will make speaker sound very low, pulseaudio can make it work sometimes. Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
