Feedback (not requested) for WIP images for unsupported board (Orange Pi 2G-IOT)
Hi there i just receive this promissing board. I update the armbian build tree and it appears on WIP. I tried to build the image but it fails on kernel building (a missing .config file), how can i help you to quick test the board?
I am using armbian wip config to build .
Please correct me and guide. ignore if it sound no sense.
uboot and kernel able to find both on board stoarge and sd card ( evo 16gb) . find below given boot and dmesg snippet.
Boot log :
NAND:  metal 28 hwcfg 4286, use eMMC, skip nand init
0 MiB
MMC:   MMC: registered mmc interface 0
Cannot find the emmc corresponding mclk adj and inv.Now use default zero. Please add it
MMC: registered mmc interface 1
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8dae6aa8
MMC: 0, MMC: 1
dmesg o/p :
[    4.468566] mmc1: card claims to support voltages below the defined range. These will be ignored.
[    4.479980] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[    4.481994] rda-mmc rda-mmc.1: set clk = 20000000, bus_clk = 200000000, divider = 4
[    4.482055] rda-mmc rda-mmc.1: set bus_width = 4
[    4.482116] mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
[    4.482482] mmc1: new SDIO card at address 4829
RDA8810 has in built toshiba slc 1.8v nand . RDA8810 kerenel needs the patch for 3.10.62
I am learning to hack and not sure how to patch for 3.10.62.
https://lkml.org/lkml/2007/3/16/437
https://patchwork.ozlabs.org/patch/222186/
https://patchwork.kernel.org/patch/7467351/
 Thanks to the help of the community We have managed to activate the NAND in linux and now the partitions denoted to Android are shown like this:
Disk /dev/mtdblock0: 24 MiB, 25165824 bytes, 49152 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/mtdblock4: 280 MiB, 293601280 bytes, 573440 sectors
I have compiled armbian community version (WIP) for Opi IoT 2G, I would like to know if it is possible to install armbian in NAND memory.
We have a total of 512MB of NAND, it is little but I think enough to incorporate a small Linux distribution (eg armbian) .
I have seen that the armbian script to install on the NAND (nand-sata-install.sh) looks in /dev/nand, but the IoT 2G Opi does not have this device. Is it possible
to remove the NAND disk (in Disk /dev/mtdblock0...4) from this card and create a /dev/nand device of 512mb?
Thank you
We are already a few users of this board. We believe that it already has enough potential for support. I myself have managed to install armbian W.I.P, community on the 512mb of NAND of this card and works well.
Thanks
