ignios Posted April 21, 2017 Share Posted April 21, 2017 Hi there i just receive this promissing board. I update the armbian build tree and it appears on WIP. I tried to build the image but it fails on kernel building (a missing .config file), how can i help you to quick test the board? Link to comment Share on other sites More sharing options...
Orange Guy Posted April 22, 2017 Share Posted April 22, 2017 fail on boot after with WIP imagehttps://pastebin.com/BBQUSrBz Link to comment Share on other sites More sharing options...
Orange Guy Posted April 22, 2017 Share Posted April 22, 2017 its no ext2 partitionon on sd card so uboot cant find boot.scr ,its on ext4 partition in /boot Link to comment Share on other sites More sharing options...
Orange Guy Posted April 23, 2017 Share Posted April 23, 2017 after today commits infinite boot loop after Started Load Kernel Modules.https://pastebin.com/kVgcAdnC Link to comment Share on other sites More sharing options...
Orange Guy Posted April 23, 2017 Share Posted April 23, 2017 need seccond boot,workinghttps://pastebin.com/uGcRqWdR Link to comment Share on other sites More sharing options...
Orange Guy Posted April 23, 2017 Share Posted April 23, 2017 dmesg outputhttps://pastebin.com/AwN5bJ5i Link to comment Share on other sites More sharing options...
Orange Guy Posted April 30, 2017 Share Posted April 30, 2017 the real nice stuff is include fbtft driver to get console on cheap arduino gpio lcd,thanks for your work Link to comment Share on other sites More sharing options...
yogesh Posted May 30, 2017 Share Posted May 30, 2017 I am using armbian wip config to build . Please correct me and guide. ignore if it sound no sense. uboot and kernel able to find both on board stoarge and sd card ( evo 16gb) . find below given boot and dmesg snippet. Boot log : NAND: metal 28 hwcfg 4286, use eMMC, skip nand init 0 MiB MMC: MMC: registered mmc interface 0 Cannot find the emmc corresponding mclk adj and inv.Now use default zero. Please add it MMC: registered mmc interface 1 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8dae6aa8 ----------------------------------------- MMC: 0, MMC: 1 dmesg o/p : [ 4.468566] mmc1: card claims to support voltages below the defined range. These will be ignored. [ 4.479980] mmc1: queuing unknown CIS tuple 0x10 (5 bytes) [ 4.481994] rda-mmc rda-mmc.1: set clk = 20000000, bus_clk = 200000000, divider = 4 [ 4.482055] rda-mmc rda-mmc.1: set bus_width = 4 [ 4.482116] mmc1: queuing unknown CIS tuple 0x10 (5 bytes) [ 4.482482] mmc1: new SDIO card at address 4829 RDA8810 has in built toshiba slc 1.8v nand . RDA8810 kerenel needs the patch for 3.10.62 I am learning to hack and not sure how to patch for 3.10.62. https://lkml.org/lkml/2007/3/16/437 https://patchwork.ozlabs.org/patch/222186/ https://patchwork.kernel.org/patch/7467351/ Link to comment Share on other sites More sharing options...
yrrahpl Posted June 14, 2017 Share Posted June 14, 2017 keyboard usb does not work Link to comment Share on other sites More sharing options...
surfero75 Posted June 17, 2017 Share Posted June 17, 2017 There is an armbian work for this board i have use it and do a version img for this board (unestable but usefull): http://surfero.blogspot.com.es/2017/06/orange-pi-2g-iot-ubuntu-1604-basado-en.html?m=1 Link to comment Share on other sites More sharing options...
surfero75 Posted June 18, 2017 Share Posted June 18, 2017 I have compile armbian for opi 2g, only for test: http://surfero.blogspot.com.es/2017/06/orange-pi-2g-iot-ubuntu-1604-basado-en.html?m=1 Link to comment Share on other sites More sharing options...
surfero75 Posted August 28, 2017 Share Posted August 28, 2017 Thanks to the help of the community We have managed to activate the NAND in linux and now the partitions denoted to Android are shown like this: Disk /dev/mtdblock0: 24 MiB, 25165824 bytes, 49152 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes [................................ ..................................] Disk /dev/mtdblock4: 280 MiB, 293601280 bytes, 573440 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes I have compiled armbian community version (WIP) for Opi IoT 2G, I would like to know if it is possible to install armbian in NAND memory. We have a total of 512MB of NAND, it is little but I think enough to incorporate a small Linux distribution (eg armbian) . I have seen that the armbian script to install on the NAND (nand-sata-install.sh) looks in /dev/nand, but the IoT 2G Opi does not have this device. Is it possible to remove the NAND disk (in Disk /dev/mtdblock0...4) from this card and create a /dev/nand device of 512mb? Thank you Link to comment Share on other sites More sharing options...
surfero75 Posted September 10, 2017 Share Posted September 10, 2017 We are already a few users of this board. We believe that it already has enough potential for support. I myself have managed to install armbian W.I.P, community on the 512mb of NAND of this card and works well. Thanks 2 Link to comment Share on other sites More sharing options...
