fever_wits Posted June 15 Share Posted June 15 (edited) Hello, I apologize in advance if I haven't put the topic in the right section. I want to share my experience with NanoPC-T6 and two NVMe m.2 disk. I use my NanoPC-T6 for a small server. In the beginning I had 2 SSDs and an M.2 to 2 SATA adapter. But I never found the right solution to power both the NanoPC-T6 and the SSDs from 1 place. After some internet searching I was able to find a solution on how to put 2 NVMe drives on my NanoPC-T6 As you know NanoPC-T6 has 1 M.2 M-Key connector with PCIe 3.0 x4 There is also one PCIe which is M.2 E-key connector with PCIe 2.1 x1 With this adapter: https://www.aliexpress.com/item/1005004762924052.html I am using M.2 E-key to M.2 M-Key. The version of the kernel I use is 6.1.43-vendor-rk35xx. The speed that the NVMe disk on the adapter board can reach is about 400MB per second, which is quite good for my needs. I am attaching some pictures. I hope this is useful for you. If there are any questions, I'm at the meeting to answer them. Regards, Edited Saturday at 02:16 PM by fever_wits 0 Quote Link to comment Share on other sites More sharing options...
