Opi5+ error omv7 install docker compose pgpkey
Go to solution Solved by Manuel Carvajal,
Hello everyone
I was trying to look for information in the forum but I can't find any topic where this specific issue is discussed. I also looked for help in the omv forum and they told me it was a problem with the distribution, hopefully you can help me.
My system running Armbian_24.5.1_Orangepi5-plus_bookworm_vendor_6.1.43_minimal
Install OMV, omv extras,
i try to configure the compose folders and i  get the 500 internal server error, clear cache, update and reboot system but there is no change,
a moderator asked me for the log by executing the following command
"Your error output is incomplete. What is the output of: sudo omv-salt deploy run compose"
orangepi5-plus:
    Function: file.managed
      Result: True
     Comment: File /etc/cron.d/omv-compose-backup is in the correct state
     Started: 13:23:54.827198
    Duration: 788.193 ms
     Changes:
      Result: True
     Comment: File /etc/cron.d/omv-compose-update is in the correct state
     Started: 13:23:55.616066
    Duration: 741.905 ms
     Changes:
      Result: True
     Comment: File /etc/cron.d/omv-compose-prune is in the correct state
     Started: 13:23:56.358647
    Duration: 830.032 ms
     Changes:
    Function: file.directory
      Result: True
     Comment: The directory /etc/docker is in the correct state
     Started: 13:23:57.189369
    Duration: 5.514 ms
     Changes:
    Function: file.serialize
      Result: True
     Comment: File /etc/docker/daemon.json updated
     Started: 13:23:57.195458
    Duration: 325.608 ms
     Changes:
              diff:
                  @@ -1,3 +1,3 @@
                  - "data-root": "/docker"
                  + "data-root": "/var/lib/docker"
    Function: pkg.installed
      Result: False
     Comment: An error was encountered while installing package(s): W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
              E: The repository 'http://apt.armbian.com bookworm InRelease' is not signed.
     Started: 13:24:03.303368
    Duration: 30382.731 ms
     Changes:
      Result: True
     Comment: All specified packages are already installed
     Started: 13:24:33.686899
    Duration: 67.916 ms
     Changes:
    Function: pkg.purged
      Result: True
     Comment: None of the targeted packages are installed or partially installed
     Started: 13:24:33.755621
    Duration: 4.062 ms
     Changes:
    Function: service.running
      Result: False
     Comment: Failed to start docker.service: Unit docker.service not found.
     Started: 13:24:33.835516
    Duration: 673.894 ms
     Changes:
      Result: True
     Comment: File /etc/systemd/system/docker.service.d/waitAllMounts.conf is in the correct state
     Started: 13:24:34.510203
    Duration: 306.575 ms
     Changes:
    Function: cmd.run
        Name: systemctl daemon-reload
      Result: True
     Comment: State was not run because none of the onchanges reqs changed
     Started: 13:24:34.822264
    Duration: 0.026 ms
     Changes:
      Result: True
     Comment: The directory /usr/local/bin is in the correct state
     Started: 13:24:34.822649
    Duration: 5.271 ms
     Changes:
    Function: file.symlink
      Result: True
     Comment: Symlink /usr/local/bin/docker-compose is present and owned by root:root
     Started: 13:24:34.828399
    Duration: 17.703 ms
     Changes:
Summary for orangepi5-plus
Succeeded: 11 (changed=1)
Failed: 2
Total states run: 13
Total run time: 34.149 s
[ERROR ] Command 'apt-get' failed with return code: 100
[ERROR ] stdout: Get:1 file:/var/cache/openmediavault/archives InRelease
Ign:1 file:/var/cache/openmediavault/archives InRelease
Get:2 file:/var/cache/openmediavault/archives Release
Ign:2 file:/var/cache/openmediavault/archives Release
Get:3 file:/var/cache/openmediavault/archives Packages
Ign:3 file:/var/cache/openmediavault/archives Packages
Get:4 file:/var/cache/openmediavault/archives Contents (deb)
Ign:4 file:/var/cache/openmediavault/archives Contents (deb)
Get:5 file:/var/cache/openmediavault/archives Contents (deb)
Ign:5 file:/var/cache/openmediavault/archives Contents (deb)
Hit:6 http://deb.debian.org/debian bookworm InRelease
Get:7 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:8 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB]
Get:9 http://security.debian.org bookworm-security InRelease [48.0 kB]
Get:10 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Get:11 http://httpredir.debian.org/debian bookworm-backports InRelease [56.5 kB]
Hit:12 https://download.docker.com/linux/debian bookworm InRelease
Hit:13 https://openmediavault.github.io/packages sandworm InRelease
Hit:14 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease
Hit:16 http://packages.openmediavault.org/public sandworm InRelease
Get:15 http://armbian.tnahosting.net/apt bookworm InRelease [53.3 kB]
Err:15 http://armbian.tnahosting.net/apt bookworm InRelease
Reading package lists...
[ERROR ] stderr: W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
[ERROR ] retcode: 100
[ERROR ] An error was encountered while installing package(s): W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
[ERROR ] The named service docker is not available
[ERROR ] Command '/usr/bin/systemd-run' failed with return code: 5
[ERROR ] stderr: Running scope as unit: run-r49a37263aed24bcf951c96199f63b03d.scope
Failed to stop docker.service: Unit docker.service not loaded.
[ERROR ] retcode: 5
[ERROR ] stderr: Running scope as unit: run-r56af566a7663456985ec54392976e370.scope
[ERROR ] retcode: 5
[ERROR ] Failed to start docker.service: Unit docker.service not found.
root@orangepi5-plus:~# >
*****"the plugin can't fix this. Your armbian repos are broken because either the gpg key is missing or your system time is off. I don't know how it could the former on a fresh install."******
and he mentions to me that the repo is having problems due to lack of a gpg key and that he doesn't know how to fix it;  I tested kernel 6.8 I could configure the docker compose well, but the USB and HDD fans had failures randomly
if someone could guide me to find a solution because so far it is the only kernel that has worked with all the hardware available in the sbc.
  • Solution
please check resolved
I also leave the steps I found to solve this error in case another user has the same problem.
the main thing about this error is that it does not connect to the server due to lack of gpg key.
with this command we make the request for the gpg key to connect to the repository without error
Quote
gpg --keyserver keyserver.ubuntu.com --recv-keys 93D6889F9F0E78D5
in my case the error gave that key 93D6889F9F0E78D5, it can change with other opi5+
the following command adds the response given by the repository and in this way we add the key to our registry to be able to connect to the repository
Quote
gpg --export -a 93D6889F9F0E78D5 | sudo apt-key add -
run the command again from the console to check if it is correct or if there is an error.
Quote
apt-get update
and after waiting about 5 minutes for everything to be checked and connected to the repository:
Quote
Succeeded: 13
Failed:     0
Total run time:    3.746 s
finally the Opi5+ running without problem :D
