RSS Bot Posted June 25 Posted June 25 This picks up from where we left off: https://github.com/armbian/build/pull/6771 Added Linux Legacy and Current. Legacy: 6.1.15 Current: 6.1.95 Wireless has been given its own function and patch directory. Bluetooth firmware added to armbian/firmware. esos.elf moved to: packages/blobs/riscv64/spacemit/ Host machine used for builds: Ubuntu Noble (aarch64) Images tested: Ubuntu Noble Minimal and Debian Sid Information: https://docs.banana-pi.org/en/BPI-F3/BananaPi_BPI-F3 https://gitee.com/bianbu-linux Flashing u-boot to eMMC: (This is not apart of the PR and needs to be added in the future.) echo 0 > /sys/block/mmcblk2boot0/force_ro sleep .50 dd if="bootinfo_emmc.bin" of="/dev/mmcblk2boot0" bs=512 conv=notrunc dd if="FSBL.bin" of="/dev/mmcblk2boot0" bs=512 seek=1 conv=notrunc dd if="FSBL.bin" of="/dev/mmcblk2boot0" bs=512 seek=512 conv=notrunc dd if="fw_dynamic.itb" of="/dev/mmcblk2" bs=512 seek=1280 conv=notrunc dd if="u-boot.itb" of="/dev/mmcblk2" bs=512 seek=2048 conv=notrunc sync Tested: Bluetooth and Wifi (useless without an ANT) Ethernet (1 and 2) PCIe USB HDMI Debug UART NOTE: One major difference between this build and the others available else where is the use of SYSLINUX/EXTLINUX instead of the ENV file. View the full article
