[Armbian build PR] - rockchip64-edge: add rkvdec2 for rk356x
Description
We can also use rkvdec2 on rk356x.
  • Remove all non-coherent-dst-bufs patches because they are suggested by a chromium developer when using libyuvimageprocessor to do NV12->AR24 convert. Now we use wayland gbm to render NV12 directly, so these patches are not necessary.
  • Add rkvdec2 nodes to devicetree of rk356x.
  • Enable rkvdec2 in kernel config and change CMA size from 128M to 384M for chromium's 4K h264 decoding.
  • Change hantro g1 vpu compatible string from rockchip,rk3568-vpu to rockchip,rk3328-vpu because they have exactly the same vpu variant data.
  • Disable h264 decoder of rk3328-vpu because there are aleady rkvdec/rkvdec2 h264 decoders on rk3328 and rk356x. Multi H264 decoders will make gstreamer and chromium confused.
  • Add chromium v4l2 decoder udev rule for rk3328-vpu
How Has This Been Tested?
Checklist:
Please delete options that are not relevant.
View the full article
