[Armbian build PR] - add new board radxa-e52c
Description
Radxa E52C is a rk3582 based board with dual 2.5G ethernet. This pr depends on https://github.com/armbian/linux-rockchip/pull/203. Since its soc is rk3582 so it should the same uboot patch from rock-5c to enable good ip cores disabled by u-boot.
How Has This Been Tested?
  • [x] ./compile.sh BOARD=radxa-e52c BRANCH=vendor BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=noble KERNEL_GIT=shallow BUILD_DESKTOP=no
  • [x] Board boots fine.
Checklist:
Please delete options that are not relevant.
View the full article
