RSS Bot Posted July 8, 2024 Posted July 8, 2024 Bumps actions/upload-artifact from 4.3.3 to 4.3.4. Release notes Sourced from actions/upload-artifact's releases. v4.3.4 What's Changed Update @actions/artifact version, bump dependencies by @robherley in actions/upload-artifact#584 Full Changelog: https://github.com/actions/upload-artifact/compare/v4.3.3...v4.3.4 Commits 0b2256b Merge pull request #584 from actions/robherley/bump-pkgs 488dcef licensed cache 04c51f5 ncc 32a9e27 bump @actions/artifact and npm audit 552bf37 new version 79616d2 Merge pull request #565 from actions/eggyhead/use-artifact-v2.1.6 See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
