DiplDi Posted May 7, 2017 Posted May 7, 2017 I took the 4.10.3 kernel cause it nows how to handle my PCTV 461e. The Installation works fine. tvheadend installation.txt
tiamat Posted February 22, 2018 Posted February 22, 2018 Thx Dirk, your instructions helped me to run tvheadend on my Orange Pi, however it seems that your init.d script is not completed. Let me show show here updated version of your script: #!/bin/bash ### BEGIN INIT INFO # Provides: tvheadend # Required-Start: $local_fs $remote_fs $network # Required-Stop: $local_fs $remote_fs $network # Should-Start: $syslog # Should-Stop: $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 # Short-Description: start/stop tvheadend Server ### END INIT INFO TVHNAME="tvheadend" TVHBIN="/usr/local/bin/tvheadend" TVHUSER="tvheadend" TVHGROUP="tvheadend" PIDFILE=/var/run/$TVHNAME.pid . /lib/lsb/init-functions start() { if [ -e $PIDFILE ]; then PID=$(ps ax | grep -v grep | grep -w $(cat $PIDFILE) | awk '{print $1}') if [ -n "$PID" ]; then echo "$TVHNAME already running (pid $PID)." exit 1 fi fi echo -n "Starting tvheadend: " start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --user ${TVHUSER} --exec ${TVHBIN} -- \ -u ${TVHUSER} -g ${TVHGROUP} -f -C echo "Done." } stop() { if [ -e $PIDFILE ]; then PID=$(ps ax | grep -v grep | grep -w $(cat $PIDFILE) | awk '{print $1}') if [ -n "$PID" ]; then echo -n "Stopping $TVHNAME: " start-stop-daemon --stop --quiet --pidfile $PIDFILE --name ${TVHNAME} echo "Done." else echo "$TVHNAME is not running." fi else echo "$TVHNAME is not running." fi } status() { if [ -e $PIDFILE ]; then PID=$(ps ax | grep -v grep | grep -w $(cat $PIDFILE) | awk '{print $1}') if [ -n "$PID" ]; then echo "$TVHNAME is running (pid $PID)." else echo "$TVHNAME is not running." [ -e $PIDFILE ] && exit 1 || exit 3 fi fi } case "$1" in start) start ;; stop) stop ;; status) status ;; restart|reload|force-reload) stop sleep 2 start ;; *) log_warning_msg "Usage: $0 {start|stop|status|restart|reload|force-reload}" >&2 exit 1 ;; esac exit 0
Marty56 Posted October 3, 2018 Posted October 3, 2018 I followed your instructions but the make command is creating errors. make Makefile:25: .config.mk: No such file or directory Makefile:751: /support/.mk: No such file or directory make: *** No rule to make target '/support/.mk'. Stop. any idea?
