RSS Bot Posted July 15, 2024 Posted July 15, 2024 Bumps setuptools from 70.2.0 to 70.3.0. Changelog Sourced from setuptools's changelog. v70.3.0 Features Support for loading distutils from the standard library is now deprecated, including use of SETUPTOOLS_USE_DISTUTILS=stdlib and importing distutils before importing setuptools. (#4137) Bugfixes pypa/distutils#268 Commits 356e9a0 Bump version: 70.2.0 → 70.3.0 822280b Merge pull request #4463 from pypa/bugfix/distutils-34f9518ef c4e64c1 Add news fragment. b01183c Merge https://github.com/pypa/distutils into bugfix/distutils-34f9518ef e221581 Merge pull request pypa/distutils#267 from msys2-contrib/customize_compiler_m... 34f9518 Merge pull request #4410 from pypa/debt/4137-deprecate-distutils-stdlib bacd9c6 sysconfig: skip customize_compiler() with MSVC Python again 4a3406b CI: also set CC/CXX when pip installing with mingw+clang e9f0be9 Merge pull request #4453 from pypa/drop-gitignore 70cda3d Use '.yml' for consistency. Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
