As a newbie struggling for a month trying to find resources to set a static IP for Wifi DHCP and to get my PC to directly communicate to my OPZ via ethernet so I can be mobile... I am ecstatic to stumble across this solution, and had to share.
Basically all you need to do is add a few bits of info to the /etc/network/interfaces file that is first made to setup wifi on the OPZ (https://www.youtube.com/watch?v=8zGRAPguaSQ).
Here is the modified /etc/network/interfaces file contents that worked for me, in blue:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static     #last word changed from dhcp in original
address 192.168.137.2   #manually set static IP: in range of default gateway found below.
netmask 255.255.255.0   #default from below line location on pc
gateway 192.168.137.1   #default pc ethernet router IP, found in "network connections>ethernet>properties>TCP IPv4" or cmd "ipconfig>ethernet autoconfig IPv4"
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet static    #last word changed from dhcp in original
address 10.0.1.99    #manually set statis IP; in range of defualt OPi gateway from below
netmask 255.255.255.0    #default from above on PC
gateway 10.0.1.1    #default OPi ethernet gateway address, from "route -ne" command, on Eth0 line
--> Descriptions for finding the relevant IP addresses directly from your PC and OPi are embedded above, but can also be found via this tutorial video which I first used  (https://www.youtube.com/watch?v=5DCPDQnRXm8)
NOTE: You have to remove the #inline description comments from the code above for it to work.
And that's it; no additional installations or configuration required on your PC or OPi... hope it helps.
