[Armbian build PR] - Bump oras-project/oras from 0.16.0 to 1.2.0 in `lib/functions/general/oci-oras.sh`
Bump oras-project/oras from 0.16.0 to 1.2.0 by bumping ORAS_VERSION in lib/functions/general/oci-oras.sh.
Release notes
Sourced from oras-project/oras's releases.
Please note that this only shows the release notes for the latest release.
New Features
  • oras is compliant with OCI image-spec v1.1.0 and distribution-spec v1.1.0
  • Introduce brand-new default terminal experience
    • Show live progress for the following commands:
      • oras copy
      • oras pull
      • oras push
      • oras attach
      • oras blob fetch
      • oras blob push
    • The new terminal experience can be turned off via the preview flag --no-tty
  • Support deletion of manifests and blobs in OCI image layout
  • Support X.509 mTLS authentication with OCI registries
Preview Features
  • BREAKING CHANGE Registries supporting Referrers API prior to distribution-spec v1.1.0-rc4 will fall back to Referrers tag schema, causing unexpected results of oras attach and oras discover commands
  • Introduce --platform to oras attach for better multi-arch attaching experience, which allows adding referrer artifact to a specific sub-platform
  • Re-purpose the flag --recursive of oras cp from extended copy to copy an artifact or a multi-arch image and its referrers
  • Promote --image-spec to a preview flag from experimental
Experimental Features
  • BREAKING CHANGE oras discover shows tree view output by default
  • Introduce formatted output via --format by implementing the specification
    • Formatted output is available to the following commands:
      • oras pull
      • oras push
      • oras attach
      • oras discover
      • oras manifest fetch
    • Examples:
      • --format json to print operation result as a JSON object
      • --format "go-template={{ .digest }}" to print the digest of the manifest using Go template
        • Template can also be specified by --template
  • Introduce oras resolve to get the digest of an artifact
Deprecation
  • oras discover: --output is marked as deprecated and succeeded by --format
Bug Fixes
  • Fix oras-project/oras#1079: Snaps build cannot read default credentials file
  • Fix oras-project/oras#1096: Mixed request number in the debug mode
  • Fix oras-project/oras#1106: Flag --plain-http=false does not work for local registries
  • Fix oras-project/oras#1129: oras cp -r fails if index has a child manifest as subject
  • Minor fixes
Other Changes
  • Improve UX
    • oras discover: show placeholder when artifactType is not presented in an index referrer
    • oras push: show artifact type when pushing files
    • Improve error message based on ORAS CLI error handling guildline
    • Improve identity token input by a new flag --identity-token to replace --password without --username
  • Improve performance
    • Reduce authentication request count fororas copy, oras manifest delete, and oras blob delete
    • Support blob mounting across repositories in the same registry for oras copy
  • Update dependencies
  • Update to Golang 1.22.3
  • Minor security enhancements
What's Changed Since RC.1
Other Changes
  • Improve documentation
Detailed Commits
Full Changelog: https://redirect.github.com/oras-project/oras/compare/v1.2.0-rc.1...v1.2.0
Notes
This release was signed with 46D3 369B 393F 6F82 71FD 1CE8 F86E C70D 2B0C 404F (@qweeah's GPG key) which can be found here.
View the full article
