salas Posted July 12, 2025 Posted July 12, 2025 @C127I forgot to ask. Is USB3 port working for you in your kernel ? 0 Quote
C127 Posted July 12, 2025 Posted July 12, 2025 Yes, it works correctly debian@orangepi5pro:~$ lsusb -t ... /: Bus 008.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 5000M |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M 0 Quote
salas Posted July 12, 2025 Posted July 12, 2025 (edited) @C127I just saw that @whywontitworkmessage and decided to try your image(0.3) directly in the sdcard ( emmc removed ) and that image does not boot. The UART is also stuck in starting kernel as mentioned by @whywontitwork, but I can get the HDMI output and the boot process drops to a initramfs shell because it can not find the root device. This is the console log. DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:22.0%,22.0% DQ rds:h5 h2 h1 h2 h1 h4 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h4 l0 h2 h3 h6 l0 h7 l0, h7 h4 h4 h4 l1 h1 h6 h7 DQS rds:l0,h2 CH2 RX Vref:25.0%, TX Vref:21.0%,21.0% DQ rds:h1 l0 h2 l2 h1 h1 h5 h1, l1 h6 l1 h3 l2 h1 h1 h2 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h3 h1 h2 h1 h4 h1 h1 h1, h4 h7 h2 h2 h3 h5 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-Pa35d-H29de-Vbf83-Bb703-R448a (Jul 02 2025 - 19:31:47 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: bypass memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 ns16550_serial serial@feb50000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.04-armbian-2024.04-S2504-Pa35d-H29de-Vbf83-Bb703-R448a (Jul 02 2025 - 19:31:47 +0000) Model: Xunlong Orange Pi 5 Pro DRAM: 16 GiB (effective 15.7 GiB) Core: 323 devices, 30 uclasses, devicetree: separate MMC: mmc@fe2c0000: 0 Loading Environment from nowhere... OK In: serial@feb50000 Out: serial@feb50000 Err: serial@feb50000 Model: Xunlong Orange Pi 5 Pro rockchip_dnl_key_pressed: no saradc device found Net: eth0: ethernet@fe1c0000 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': No EFI system partition No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2c0000.bootdev': 1 script ready mmc 1 mmc@fe2c0000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@fe2c0000.bootdev.part_1' with script Boot script loaded from mmc 0:1 200 bytes read in 4 ms (48.8 KiB/s) 15754859 bytes read in 1321 ms (11.4 MiB/s) 39287296 bytes read in 3289 ms (11.4 MiB/s) 162018 bytes read in 28 ms (5.5 MiB/s) Working FDT set to 12000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ## Loading init Ramdisk from Legacy Image at 12180000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15754795 Bytes = 15 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to ebf92000, end ece9862b ... OK Loading Device Tree to 00000000ebf02000, end 00000000ebf91fff ... OK Working FDT set to ebf02000 Starting kernel ... Setting loglevel=8 and verbose=8 shows this is console: [ 2.028301] dwmmc_rockchip fe2d0000.mmc: IDMAC supports 32-bit address mode. [ 2.029020] dwmmc_rockchip fe2d0000.mmc: Using internal DMA controller. [ 2.029624] dwmmc_rockchip fe2d0000.mmc: Version ID is 270a [ 2.030163] dwmmc_rockchip fe2d0000.mmc: DW MMC controller at irq 84,32 bit host data width,256 deep fifo [ 2.031384] dwmmc_rockchip fe2d0000.mmc: allocated mmc-pwrseq [ 2.031921] mmc_host mmc2: card is non-removable. [ 2.217056] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 2.250531] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.376463] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 2.409028] dwmmc_rockchip fe2d0000.mmc: Successfully tuned phase to 223 [ 2.423188] mmc2: new UHS-I speed SDR104 SDIO card at address 0001 [ 2.953845] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 2.991412] mmc0: error -110 whilst initialising SD card [ 3.527479] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 4.257059] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 4.271710] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) [ 4.831481] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 5.560980] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 5.575632] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) [ 6.140278] dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway [ 6.869893] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) Edited July 12, 2025 by salas 0 Quote
C127 Posted July 12, 2025 Posted July 12, 2025 (edited) You are right, this is a strange DTS issue. U-Boot is working, but the kernel can't initialize the SD card, which is why it drops to the initramfs shell. Unfortunately, I can't reproduce this specific error myself, but I agree with the analysis. I suspect this is the same reason why newer U-Boot versions initially failed to boot for me. I will start working on fixing the DTS next week. Thanks for finding this bug! Edited July 13, 2025 by C127 0 Quote
salas Posted July 21, 2025 Posted July 21, 2025 (edited) Quote Unfortunately, I can't reproduce this specific error myself, but I agree with the analysis. I suspect this is the same reason why newer U-Boot versions initially failed to boot for me. @C127 I've been thinking... Are you using an M.2 disk as the root device? I only noticed the dropping to initramfs problem after removing my emmc. Maybe if you are using a M.2 disk that is masking the problem Edited July 21, 2025 by salas 0 Quote
C127 Posted July 21, 2025 Posted July 21, 2025 Hi @salas, Quote Any progress on the DTS? Unfortunately, no. In my free time, I've only had time for small patches and bug fixes. I've been trying to get it working on newer u-boot versions (v2025.07), but without any luck so far, I'll be busy this week, but I can probably release a new update next month (August). Quote I've been thinking... Are you using an M.2 card as the root device? I only noticed the dropping to initramfs problem after removing my emmc. Maybe if you are using a M.2 disk that is masking the problem I've tried it with and without an M.2 drive using the SD card as boot and root, but I can't reproduce it. 0 Quote
salas Posted July 21, 2025 Posted July 21, 2025 Quote Unfortunately, no. In my free time, I've only had time for small patches and bug fixes. I've been trying to get it working on newer u-boot versions (v2025.07), but without any luck so far, I'll be busy this week, but I can probably release a new update next month (August). Not a problem. Just please do not give up I have 5 units of those waiting for a newer kernel LoL 0 Quote
C127 Posted July 23, 2025 Posted July 23, 2025 Good news! I have finally built a new image (v0.7). It uses the v2025.07 u-boot from the 'orangepi5-pro-uboot' branch, and now the eMMC is working correctly. (Thanks to @salas for testing!) 0 Quote
Fabricio Martínez Tamayo Posted August 24, 2025 Posted August 24, 2025 Hi everyone, Sorry to bother you with what may be a basic question. I’m not very experienced with the Armbian build system, and it’s been a while since I last built and deployed my own kernels. I’ve been trying to compile both the current and edge branches without success. I did get vendor working. I came across this post but I’m still unclear on the exact steps. Could someone please give me a simplified explanation of: What needs to be done to successfully compile these branches? Where I can get the latest patches, and how to apply them? Whether I also need to rebuild U-Boot with the Armbian build system. Thanks a lot in advance for your help! 0 Quote
laibsch Posted August 24, 2025 Posted August 24, 2025 2 hours ago, Fabricio Martínez Tamayo said: What needs to be done to successfully compile these branches? 'for kernel in current edge vendor;do ./compile.sh BOARD=orangepi5pro BUILD_DESKTOP="no" BRANCH=$kernel RELEASE=noble KERNEL_CONFIGURE=no BUILD_MINIMAL=yes SHARE_LOG=yes;done' should do it, for example. That would get you an image with an Armbian-patched kernel of the current, edge and vendor flavor. It's really THAT simple :-D 1 Quote
Fabricio Martínez Tamayo Posted August 25, 2025 Posted August 25, 2025 (edited) Hi, I can confirm I got a booting SD card with the suggested command. I ended up using the following: ./compile.sh BOARD=orangepi5pro BUILD_DESKTOP=no BRANCH=edge RELEASE=bookworm KERNEL_CONFIGURE=no BUILD_MINIMAL=yes SHARE_LOG=yes Thank you very much @laibsch. Cheers! P.S. I ended up buying a USB-UART adapter as you suggested in another thread to test another orange pi 5 board I have but it seems that one is dead. Edited August 25, 2025 by Fabricio Martínez Tamayo 0 Quote
laibsch Posted August 25, 2025 Posted August 25, 2025 I am glad to hear of your success 11 hours ago, Fabricio Martínez Tamayo said: ./compile.sh BOARD=orangepi5pro BUILD_DESKTOP=no BRANCH=edge RELEASE=bookworm KERNEL_CONFIGURE=no BUILD_MINIMAL=yes SHARE_LOG=yes Beware that edge is the bleeding edge and where we break things. Vendor is the one the board maker supplied you with, most likely outdated and hacked up. You are usually best off with the current kernel, except of course when there was some recent hardware enablement work going on in the edge kernel for your work. 1 Quote
