RSS Bot Posted July 22, 2024 Posted July 22, 2024 Bumps setuptools from 70.3.0 to 71.1.0. Changelog Sourced from setuptools's changelog. v71.1.0 Features Added return types to typed public functions -- by :user:Avasam Marked pkg_resources as py.typed -- by :user:Avasam (#4409) Misc #4492 v71.0.4 Bugfixes Removed lingering unused code around Distribution._patched_dist. (#4489) v71.0.3 Bugfixes Reset the backports module when enabling vendored packages. (#4476) v71.0.2 Bugfixes Include all vendored files in the sdist. (#4480) v71.0.1 Bugfixes ... (truncated) Commits 08bd311 Bump version: 71.0.4 → 71.1.0 e3fd44a Merge pull request #4492 from mgorny/core-deps-spec 022cedb Switch to uv for vendoring. 3fca249 Merge pull request #4500 from Avasam/Update-mypy-to-1.11 e7575ae Update pyproject.toml b078d6e Merge pull request #4409 from Avasam/pkg_resources-explicit-public-return-ann... 3aba4d4 Update mypy to 1.11 deb0aa8 Merge branch 'main' of https://github.com/pypa/setuptools into pkg_resources-... 48f95c0 Bump version: 71.0.3 → 71.0.4 7d0178e Merge pull request #4493 from pypa/debt/4489-patched-dist Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
