[Armbian build PR] - build(deps): bump setuptools from 71.1.0 to 72.1.0
Bumps setuptools from 71.1.0 to 72.1.0.
Changelog
Sourced from setuptools's changelog.
v72.1.0
Features
  • Restore the tests command and deprecate access to the module. (#4519) (#4520)
v72.0.0
Deprecations and Removals
  • The test command has been removed. Users relying on 'setup.py test' will need to migrate to another test runner or pin setuptools before this version. (#931)
Commits
  • 441799f Bump version: 72.0.0 → 72.1.0
  • 59aff44 Merge pull request #4522 from pypa/feature/graceful-drop-tests
  • c437aaa Restore the tests command and deprecate access to the module.
  • a6726b9 Add celery and requests to the packages that test integration. Ref #4520
  • 5e1b3c4 Bump version: 71.1.0 → 72.0.0
  • 4c0b9f3 Merge pull request #4458 from pypa/debt/remove-test-command
  • be8e3a0 Merge pull request #4507 from pypa/docs/4483-install-core-extra
  • 99d2c72 Add documentation clarifying how to reliably install setuptools with its depe...
  • 63c89f9 👹 Feed the hobgoblins (delint).
  • c405ac1 Merge branch 'main' into debt/remove-test-command
  • See full diff in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
