[Armbian build PR] - build(deps): bump ossf/scorecard-action from 2.3.3 to 2.4.0
Bumps ossf/scorecard-action from 2.3.3 to 2.4.0.
Release notes
Sourced from ossf/scorecard-action's releases.
v2.4.0
What's Changed
This update bumps the Scorecard version to the v5 release. For a complete list of changes, please refer to the v5.0.0 release notes. Of special note to Scorecard Action is the Maintainer Annotation feature, which can be used to suppress some Code Scanning false positives. Alerts will not be generated for any Scorecard Check with an annotation.
Documentation
New Contributors
Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.3.3...v2.4.0
Commits
  • 62b2cac bump docker tag to v2.4.0 for release (#1414)
  • c09630c lower license score alert threshold to 9 (#1411)
  • cf8594c :seedling: Bump github.com/sigstore/cosign/v2 from 2.2.4 to 2.3.0 (#1413)
  • de5fcb9 :seedling: Bump the github-actions group with 2 updates (#1412)
  • a46b90b bump scorecard to v5.0.0 release (#1410)
  • 9fc518d :seedling: Bump golang in the docker-images group (#1407)
  • a8eaa1b :seedling: Bump the github-actions group with 2 updates (#1408)
  • 873d5fd :seedling: Bump the github-actions group across 1 directory with 2 updates (#...
  • 54cc1fe :seedling: Bump the docker-images group with 2 updates (#1401)
  • 82bcb91 :seedling: Bump golang.org/x/net from 0.26.0 to 0.27.0 (#1400)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
