Panda Posted August 2, 2024 Posted August 2, 2024 Hello people, I'm trying to compile armbian to run on my TV Box. If I use the image Hinlink ht2 I can boot without problem, but if I try to compile my version of Armbian, the tv box does not boot. I'm using the follow sintax to compile: ./compile.sh build BOARD=hinlink-ht2 BRANCH=legacy BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base EXPERT=yes KERNEL_GIT=shallow DEB_COMPRESS=xz I haven't the TTL to debug. What I already tryed: Burn the hinlink ht2 image to SD card and change the ROOT partition to my image (no work) Burn my image to SD card and copy the boot partition of hinlink to boot partition on SD Card (no work) Burn hinlink ht2 image and get the dtb and put on my image (no work) I'm accept any suggestion. Why I'm trying to compile ? The Ethernet is not working, on my board it uses the gmac0 and the hinlink ht2 uses gmac1 regards. Panda 0 Quote
