SPI on rock s0
Go to solution Solved by grixm,
Posted (edited)
Hi guys, I got a SPIdev overlay to work on the rock S0, figured I'd just share it here for the record, since I could have used this info myself (I spent days trying to figure it out since I had no experience with device trees or whatnot).
Basically, download the attached .dts file, then run
sudo armbian-add-overlay rk3308-spi2-spidev.dts
I also edited /boot/armbianEnv.txt and added this line, but I'm unsure if that's actually necessary?
param_spidev_spi_bus=2
This worked on Armbian 24.5.1 Noble, creating /dev/spidev2.0. You can verify that it works using this tool: https://github.com/rm-hull/spidev-test
The dts file is based on this one from radxa, however changed to "fragment@" syntax like other armbian overlays: https://github.com/radxa-pkg/radxa-overlays/blob/main/arch/arm64/boot/dts/rockchip/overlays/rk3308-spi2-spidev.dts
Maybe this will also work on Rock Pi S, but haven't tested.
Edited by grixm
Posted (edited)
No I don't think it has ADC. But you can use the numerous SPI or i2c ports to connect an external adc.
Edited by grixm
Posted (edited)
Ty.
I picked up a cheap sda1115 ADC which uses I2C.
Will i2c on the Rock-S0 need an overlay or is it already enabled by default in armbian. Haven't figured out how to test for that yet.
NM - it "just works", I didn't have to change anything or add an overlay! 🙂
Edited by Meestor_X
On 1/6/2025 at 8:06 PM, Meestor_X said:
(Got the overlays working finally)
What did you do? I am also experiencing all my overlays breaking after updating the armbian version.
Posted (edited)
It's been a while, but I believe it was the prefix issue. Perhaps it's been fixed now?
https://github.com/armbian/configng/issues/360#issuecomment-2573855215
A big part of getting to the bottom of overlay issues is to use a TTL->USB adapter to watch the boot process.
Edited by Meestor_X
Posted (edited)
@Meestor_X
I see, unfortunately it doesn't seem to work for me. I don't use official overlays, just user overlays. Tried every combination of with or without prefix in the filename and in armbianEnv.txt and none of them work. I tried to monitor the boot process but I found that my TTL->USB adapter seems to be about 10x too slow for the baudrate used.
In addition, I don't know if this is something you saw too, but armbian-config crashed when I try to enter the overlay config menu, with the message "Invalid overlay_prefix rk3308".
Guess I'm stuck on 24.11 for the time being. Or I can try installing 25.2 from scratch rather than update, maybe it will be different.
Edited by grixm
Understood. I'm still on 24.x.x so I don't know if the later ones are better.
I tried for a while without, but honestly, you gotta get yourself a TTL -> USB that works so you can follow the log. Once you do that, you'll see the errors clear as day as to why the overlays aren't being loaded.
Not sure what country you're in, but in NA they're quite inexpensive. This is the one I got:
https://www.amazon.com/Serial-Adapter-Signal-Prolific-Windows/dp/B08BLKBK1K
Turns out it wasn't the overlays failing to be recognized after all, one of the overlays were simply wrong, because the base device tree had changed. And if even just one of the user overlays was invalid, they all failed to load.
If anyone reads this with the same problem after using my overlay: In rk3308-spi1-spidev.dts, you need to change the word "acodec" (in fragment@2 near the bottom) to just "codec".
