[Armbian build PR] - opi3b: fix mainline uboot with vendor kernel and fix uwe5622 bt for rk35xx
RSS Bot
Description
6.1 vendor kernel is not bootable on opi3b. There is a post in forum: https://forum.armbian.com/topic/36332-orangepi3b-kernel-panic-when-trying-to-boot-with-the-new-vendor-kernel6143/#comment-186436
Opi3b is using mainline uboot for all branches which is not compatibale with vendor kernel's npu, ~so I use radxa's rockchip uboot instead and limit mainline uboot to branch edge~. I find that setting vdd_npu with property regulator-always-on will fix the issue. There is also a missing uwe5622 patch on rk35xx family, which will cause kernel panic of sprdbt_tty kernel module.
  • [x] ./compile.sh BOARD=orangepi3b BRANCH=vendor BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=noble KERNEL_GIT=shallow BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base
  • [x] Opi3b vendor kernel can boot now
Checklist:
Please delete options that are not relevant.
View the full article
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
