is it possible boot orange pi zero over usb using USB-DM2 and USB-3DM3 ports with opi zero expansion board?
Hi friends,
            I have read a lot document about booting orange pi zero over usb flash. I flashed latest mainline u-boot to orange pi's SPI Flash. I can boot the system via the usb port which is next to the ethernet. Can I boot the system via the usb ports USB2 and USB3 that the h2+ has and the expansion card that can use it?. I can not see these USB's through u-boot terminal. thanks.
=> Usb reset
Resetting USB ...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
Scanning bus 0 for devices ... 1 USB Device (s) found
       Scanning usb for storage devices ... 0 Storage Device (s) found
=> Usb reset
Resetting USB ...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
=> Usb info
1: Hub, USB Revision 2.0
 - u-boot EHCI Host Controller
 - Class: Hub
 - PacketSize: 64 Configurations: 1
 - Vendor: 0x0000 Product 0x0000 Version 1.0
   Configuration: 1
   - Interfaces: 1 Self Powered 0mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 1
     - Class Hub
     - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
