RSS Bot Posted August 10, 2024 Posted August 10, 2024 Amlogic A113X 1Gb RAM eMMC 8Gb USB (1 port) Ethernet Wireless Realtek 8189FSTV / Z-WAVE There is currently no easy way to flash the IMG. In order to test the build Flash Jethub D1 IMG using the aml-flash-tool Flash Gateway-gz80x IMG to a USB stick Power on unit and input user information or bypass Insert USB stick, reboot sudo reboot. (You should now be booting from the USB stick) Input user information and execute sudo armbian-install and transfer to eMMC When done; power down, pull USB stick and power on. In the future we need to be able to generate IMGs that can be flashed using the aml-flash-tool. NOTE: USB storage isn't detected in U-Boot, when cold booting from the Jethub img. This is why it requires a reboot before we can boot from USB. View the full article
