RSS Bot Posted August 11, 2024 Posted August 11, 2024 Description Disable saving state of leds such as: enP1p1s0-0::lan enP1p1s0-1::lan enP1p1s0-2::lan enP1p1s0-3::lan enP2p1s0-0::lan enP2p1s0-1::lan enP2p1s0-2::lan enP2p1s0-3::lan These leds are not manageable and when restored trow up errors in kernel ring buffer [ 13.964507] leds enP1p1s0-0::lan: Setting an LED's brightness failed (-524) [ 13.989055] leds enP1p1s0-0::lan: Setting an LED's brightness failed (-524) [ 13.989100] leds enP1p1s0-1::lan: Setting an LED's brightness failed (-524) [ 14.021133] leds enP1p1s0-1::lan: Setting an LED's brightness failed (-524) [ 14.021176] leds enP1p1s0-2::lan: Setting an LED's brightness failed (-524) [ 14.070622] leds enP1p1s0-2::lan: Setting an LED's brightness failed (-524) [ 14.073070] leds enP1p1s0-3::lan: Setting an LED's brightness failed (-524) [ 14.097028] leds enP1p1s0-3::lan: Setting an LED's brightness failed (-524) [ 14.097066] leds enP2p1s0-0::lan: Setting an LED's brightness failed (-524) [ 14.132938] leds enP2p1s0-0::lan: Setting an LED's brightness failed (-524) [ 14.132982] leds enP2p1s0-1::lan: Setting an LED's brightness failed (-524) [ 14.154556] leds enP2p1s0-1::lan: Setting an LED's brightness failed (-524) [ 14.157496] leds enP2p1s0-2::lan: Setting an LED's brightness failed (-524) [ 14.197328] leds enP2p1s0-2::lan: Setting an LED's brightness failed (-524) [ 14.197371] leds enP2p1s0-3::lan: Setting an LED's brightness failed (-524) [ 14.214507] leds enP2p1s0-3::lan: Setting an LED's brightness failed (-524) How Has This Been Tested? [x] running correctly on nanopi-r5c and orangepi-5-plus --> enP* entries are not saved to armbian-leds.conf Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
