Frank White Posted March 28 Posted March 28 (edited) Hi Nick, I was able to burn the following image to my SD card and it booted up perfectly. I have version 5.1 of the board. The only problem I noticed is neither the wifi nor ethernet port were working. Any tips? Armbian-unofficial_25.05.0-trunk_X96q-ddr3-v5-1_noble_edge_6.12.11_xfce_desktop.img.xz Edited March 28 by Frank White 0 Quote
Nick A Posted March 28 Posted March 28 Which wifi chip do you have? Can you upload your dmesg logs here? 0 Quote
Frank White Posted March 28 Posted March 28 (edited) Here's my board. I will get dmesg in a bit. I guess it's the XR819 chip. Edited March 28 by Frank White 0 Quote
Nick A Posted March 28 Posted March 28 Can you extract your dts from your original android. You directory structure might be different. 0 Quote
Frank White Posted March 28 Posted March 28 4 hours ago, Nick A said: Can you extract your dts from your original android. Not sure I did this correctly but here's what I got. dtb.0.dts 0 Quote
Frank White Posted March 29 Posted March 29 8 hours ago, Nick A said: Try this image Everything seemed to work except sound. Thanks for your help. My first impression is that while super cool, the hardware isn't up to the task of running a desktop OS. I'm going to try out the server version and see how that does. 0 Quote
Frank White Posted March 29 Posted March 29 Off topic question but I don't suppose you could point me in the right direction to get openwrt installed on my device? 0 Quote
Nick A Posted March 29 Posted March 29 (edited) Sorry I never played with openwrt on these boxes. I found this.. not sure how it works. But I see x96q-lpddr3. https://github.com/armarchindo/ULO-Builder Edited March 29 by Nick A 0 Quote
vok4us Posted April 1 Posted April 1 Hi. In October 2024, I wrote that I had a problem installing Armbian on eMMC of the tv box. I managed to solve this problem. Here's what you need to do: 1. Download the image from the link - https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_xfce_desktop.img.xz 2. Burn the image to microSD using Rufus or BalenaEtcher 3. Insert the microSD and turn on the tv box 4. Install Armbian 5. Next, launch the terminal and enter sequentially: armbian-install -> Boot from eMMC - system on eMMC -> ext4 (waiting ~5-10 minutes) 6. Turn off the tv box and extract the microSD 7. Turn on the tv box (Wi-Fi is not working) 8. Next, launch the terminal and enter sequentially: armbian-config -> System -> Kernel -> SY210 - Manage device tree overlays 9. Turn off the tv box (waiting ~5-10 minutes) 10. Turn on the tv box (Wi-Fi is working) Special thanks to @Nick A Good luck to all!!! 0 Quote
ketzercat Posted April 2 Posted April 2 Good afternoon, I picked up the next X96Q. I was deceived, of course. But the price is not something that will upset me. Instead of the 2 and 16 written on the sticker, there are 1 and 8 inside. Otherwise, there is an extremely unsuspicious serial number. But here I come to another question, how realistic is it to launch Armbian on this? 0 Quote
Nick A Posted April 3 Posted April 3 Hi @ketzercat I have 4 different images.. Try them see if they work for you. https://github.com/NickAlilovic/build/releases/tag/20250306 0 Quote
IronIgel Posted April 6 Posted April 6 Hi @ketzercat, your box is not based on an Allwinner H313 but most likely on a soc from HiSilicon. H313 is rectangle but not square and the silkscreen is different. The board looks almost like the one I received some time ago: https://forum.armbian.com/topic/43682-armbian-for-h313-x96-q-lpddr3-tv-box/#findComment-202383 So, no chance of running Armbian any time soon.... 0 Quote
Frank White Posted April 15 Posted April 15 Any tip to getting HDMI audio to work on version 5.1 of the board? 0 Quote
akhems Posted April 17 Posted April 17 Hey Everyone. I have a cheap box from Aliexpress. On the board it says "Q1 V3.0" The chip on it says H313. What would be the best image to use for this? And how can i get it to boot from SD or USB with the image? thank you! 0 Quote
akhems Posted April 18 Posted April 18 Just tried booting with a SD card made using instructions from page 2 of this thread. Just boots into normal Android OS Tried using a toothpick in the audio port, just get a black screen Any advice on how to get the box to boot from SD card? 0 Quote
Nick A Posted April 18 Posted April 18 Try my latest images maybe they will work for you https://github.com/NickAlilovic/build/releases/tag/20250306 0 Quote
rafaeldavid Posted Wednesday at 09:43 PM Posted Wednesday at 09:43 PM Hello everyone, I have a problem, I hope you can help me. I have a TV box sold here in Brazil that has an H316 processor. I tried to use the images that were made available, but I only managed to boot successfully when I compiled my own after downloading the build from Git. Now I can boot from the SD card, create a user and passwords, use the sudo armbian-install command, but after that, a message appears saying "Counting files... few seconds" and freezes on that screen. Could someone tell me what I can change in the img compilation to fix this? 0 Quote
Nick A Posted yesterday at 12:31 AM Posted yesterday at 12:31 AM Which build are you using? Is your internal emmc detected on boot? 0 Quote
eas07027 Posted yesterday at 08:27 AM Posted yesterday at 08:27 AM On 9/20/2024 at 12:56 AM, sicxnull said: обновил свой форк, если вы хотите его использовать https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz The home assistant is installed perfectly, but it does not load on emmc. On 4/18/2025 at 6:13 PM, Nick A said: Try my latest images maybe they will work for you https://github.com/NickAlilovic/build/releases/tag/20250306 It is installed perfectly on emmc, but the home assistant is not installed, according to the instructions https://community.home-assistant.io/t/installing-home-assistant-supervised-using-debian-12/200253 0 Quote
Nick A Posted yesterday at 04:00 PM Posted yesterday at 04:00 PM (edited) @eas07027 That install guide is for x86. dpkg -i os-agent_1.7.2_linux_x86_64.deb Try this https://community.home-assistant.io/t/installing-home-assistant-supervised-on-a-raspberry-pi-using-debian-12/247116 I haven’t installed home assistant before so I can’t help much. If home assistant is using docker you need to run these commands. Edited yesterday at 04:08 PM by Nick A 0 Quote
eas07027 Posted yesterday at 07:33 PM Posted yesterday at 07:33 PM I have solved the issue of installing on a new system. sudo update-alternatives --config iptables Choose -legacy 0 Quote
rafaeldavid Posted 23 hours ago Posted 23 hours ago (edited) 22 hours ago, Nick A said: Which build are you using? Is your internal emmc detected on boot? I tried generating some builds, the only one that works (initially) is Armbian-unofficial_25.05.0-trunk_X96q_jammy_current_6.12.23 (versions with or without desktop). I don't understand much, but I believe that the emmc memory is detected. When I start it, it boots, asks the initial questions (root password, create my user, region settings, etc.). After that, I use the armbian-install command and enter the installer, select to install, ask me to confirm (data will be deleted), ask how I want to format the partition and then get stuck. PS: To mount the image I used this command: ./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no RELEASE=jammy (I tried to use the version BOARD=x96q-mate, but don't work! As you can see in the video, the image shakes for a while, then stops. I think that's when the device freezes. VID-20250509-WA0007.mp4 Edited 23 hours ago by rafaeldavid 0 Quote
Nick A Posted 22 hours ago Posted 22 hours ago @rafaeldavid can you show me the output when you type in the command "fdisk -l" 0 Quote
rafaeldavid Posted 8 hours ago Posted 8 hours ago 13 hours ago, Nick A said: @rafaeldavid can you show me the output when you type in the command "fdisk -l" 0 Quote
rafaeldavid Posted 8 hours ago Posted 8 hours ago I tried using the armbian-upgrade command, but it gave an error and froze everything. 0 Quote
Nick A Posted 7 hours ago Posted 7 hours ago I wouldn’t upgrade without freezing the kernel update first. It looks like you copied something to emmc. It takes awhile to copy everything to emmc. 0 Quote
rafaeldavid Posted 6 hours ago Posted 6 hours ago (edited) 1 hour ago, Nick A said: I wouldn’t upgrade without freezing the kernel update first. It looks like you copied something to emmc. It takes awhile to copy everything to emmc. How long does it take? I left it on overnight, for about 11 hours, and it just stayed on the same image. The upgrade was just for testing... But I've already redone Armbian to the original. Edited 6 hours ago by rafaeldavid 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago It shouldn’t take that long.. did you try booting without the sdcard? 0 Quote
