Nick A Posted Friday at 05:03 PM Posted Friday at 05:03 PM Your tv stick probably has secure boot enabled. You can compile a secure boot image using these steps. 1 Quote
Randlin Posted Friday at 05:58 PM Posted Friday at 05:58 PM Nice! I'll try that. Thank you for your help so far. Finding the right documentation has been a little tricky for me and I really appreciate the help. 0 Quote
Randlin Posted Friday at 09:23 PM Posted Friday at 09:23 PM Alright, I built the x96q-lpddr3 image using the patches suggested. It booted (partially). Nothing on the screen, but it is starting! I chose that image because it is H313 and lpddr3 (the android uboot build that worked before detected it as such) I attached the serial log. It's getting late here and I may not get much more done on this until Monday, but this is a good sign in my opinion. uboot.txt 0 Quote
Nick A Posted Friday at 11:24 PM Posted Friday at 11:24 PM (edited) H313/H616/H618 are pretty much the same SOC. It’s the AXP power management IC that’s different. Also RAM and WIFi chips are usually different. https://linux-sunxi.org/AXP_PMICs Edited Saturday at 12:08 AM by Nick A 0 Quote
Randlin Posted 6 hours ago Posted 6 hours ago Cool, good to know. I'll try one with the same AXP and go from there. 0 Quote
Randlin Posted 6 hours ago Posted 6 hours ago Hmm, according to the config, the X96q lpddr3 uses the AXP313 already. Maybe ram is wrong? Pretty sure it's lpddr3, if there is any way to check that, I can. Gonna do a little digging in android. 0 Quote
Randlin Posted 6 hours ago Posted 6 hours ago According to Android uboot, DRAM_VCC= 1200mv DRAM CLK =648 MHZ DRAM TYPE=7 (lpddr3) DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061 gonna try some of this in the x96q image, see what happens 0 Quote
Randlin Posted 6 hours ago Posted 6 hours ago Hmm, in boot log I see AXP1530 mentioned in theandroid boot (booted off the sd card, not emmc). I attached the log. bootinfo.txt 0 Quote
Randlin Posted 4 hours ago Posted 4 hours ago I set the dram speed to 648, no difference. Gotta be the axp or another option. 0 Quote
