Nick A Posted Friday at 05:03 PM Posted Friday at 05:03 PM Your tv stick probably has secure boot enabled. You can compile a secure boot image using these steps. 1 Quote
Randlin Posted Friday at 05:58 PM Posted Friday at 05:58 PM Nice! I'll try that. Thank you for your help so far. Finding the right documentation has been a little tricky for me and I really appreciate the help. 0 Quote
Randlin Posted Friday at 09:23 PM Posted Friday at 09:23 PM Alright, I built the x96q-lpddr3 image using the patches suggested. It booted (partially). Nothing on the screen, but it is starting! I chose that image because it is H313 and lpddr3 (the android uboot build that worked before detected it as such) I attached the serial log. It's getting late here and I may not get much more done on this until Monday, but this is a good sign in my opinion. uboot.txt 0 Quote
Nick A Posted Friday at 11:24 PM Posted Friday at 11:24 PM (edited) H313/H616/H618 are pretty much the same SOC. It’s the AXP power management IC that’s different. Also RAM and WIFi chips are usually different. https://linux-sunxi.org/AXP_PMICs Edited Saturday at 12:08 AM by Nick A 0 Quote
Randlin Posted 16 hours ago Posted 16 hours ago Cool, good to know. I'll try one with the same AXP and go from there. 0 Quote
Randlin Posted 16 hours ago Posted 16 hours ago Hmm, according to the config, the X96q lpddr3 uses the AXP313 already. Maybe ram is wrong? Pretty sure it's lpddr3, if there is any way to check that, I can. Gonna do a little digging in android. 0 Quote
Randlin Posted 15 hours ago Posted 15 hours ago According to Android uboot, DRAM_VCC= 1200mv DRAM CLK =648 MHZ DRAM TYPE=7 (lpddr3) DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061 gonna try some of this in the x96q image, see what happens 0 Quote
Randlin Posted 15 hours ago Posted 15 hours ago Hmm, in boot log I see AXP1530 mentioned in theandroid boot (booted off the sd card, not emmc). I attached the log. bootinfo.txt 0 Quote
Randlin Posted 14 hours ago Posted 14 hours ago I set the dram speed to 648, no difference. Gotta be the axp or another option. 0 Quote
Nick A Posted 8 hours ago Posted 8 hours ago (edited) AXP1530 is the same as AXP313a. Take a look at the link I posted above. You could use this tool to extract your dram settings from an android update or boot0.bin. https://github.com/apritzel/sunxi-fw sunxi-fw info -v boot0.bin Edited 8 hours ago by Nick A 0 Quote
Randlin Posted 8 hours ago Posted 8 hours ago I did notice in the log: INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 0 Quote
Randlin Posted 8 hours ago Posted 8 hours ago Wait, that was the Linux kernel, not uboot. I'll get that 0 Quote
Randlin Posted 8 hours ago Posted 8 hours ago /sunxi-fw info -v fulldisk.img @ 0: mbr: DOS MBR protective MBR, GPT used GPT version 00010000 usable disk size: 7419 MB number of partition entries: 17 @ 16: toc0: signed boot image 2 items size: 98304 bytes @ 321: toc0: signed boot image 2 items size: 98304 bytes @26812: fit: U-Boot FIT image fit:__overlay__: "<no description>" fit:__overlay__: "<no description>" fit:fragment@2: "<no description>" So I never dumped just boot0 (and no firmware update available), but I have full emmc dump named fulldisk.img. I would assume it is the toc0? Trying to extract does not work , however: (maybe because there are two?) /sunxi-fw extract -v -n toc0 -o uboot0 /home/Tr/fulldisk.img unknown image file extracting the mbr works fine though. 0 Quote
Nick A Posted 8 hours ago Posted 8 hours ago This post should help extracting your boot.img from android. That’s if your box is already rooted. 0 Quote
Randlin Posted 7 hours ago Posted 7 hours ago (edited) Oh, so it is the devicetree of Linux we want. My bad. Here it is: devicetree.txt FYI I was able to use binwalk -e on the boot partition dump, nice to see there is another way. Thanks for all the help Edited 7 hours ago by Randlin 0 Quote
Nick A Posted 7 hours ago Posted 7 hours ago (edited) Actually in that post it was about downloading the boot_a partition. Then extracting the dts.. you can skip the dts extraction part for now. We need your boot_a partition. also that’s not the android dts you posted. It has some info but not all of it. Edited 5 hours ago by Nick A 0 Quote
