Nick A Posted Friday at 05:03 PM Posted Friday at 05:03 PM Your tv stick probably has secure boot enabled. You can compile a secure boot image using these steps. 1 Quote
Randlin Posted Friday at 05:58 PM Posted Friday at 05:58 PM Nice! I'll try that. Thank you for your help so far. Finding the right documentation has been a little tricky for me and I really appreciate the help. 0 Quote
Randlin Posted Friday at 09:23 PM Posted Friday at 09:23 PM Alright, I built the x96q-lpddr3 image using the patches suggested. It booted (partially). Nothing on the screen, but it is starting! I chose that image because it is H313 and lpddr3 (the android uboot build that worked before detected it as such) I attached the serial log. It's getting late here and I may not get much more done on this until Monday, but this is a good sign in my opinion. uboot.txt 0 Quote
Nick A Posted Friday at 11:24 PM Posted Friday at 11:24 PM (edited) H313/H616/H618 are pretty much the same SOC. It’s the AXP power management IC that’s different. Also RAM and WIFi chips are usually different. https://linux-sunxi.org/AXP_PMICs Edited Saturday at 12:08 AM by Nick A 0 Quote
Randlin Posted Monday at 02:07 PM Posted Monday at 02:07 PM Cool, good to know. I'll try one with the same AXP and go from there. 0 Quote
Randlin Posted Monday at 02:20 PM Posted Monday at 02:20 PM Hmm, according to the config, the X96q lpddr3 uses the AXP313 already. Maybe ram is wrong? Pretty sure it's lpddr3, if there is any way to check that, I can. Gonna do a little digging in android. 0 Quote
Randlin Posted Monday at 02:26 PM Posted Monday at 02:26 PM According to Android uboot, DRAM_VCC= 1200mv DRAM CLK =648 MHZ DRAM TYPE=7 (lpddr3) DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061 gonna try some of this in the x96q image, see what happens 0 Quote
Randlin Posted Monday at 02:35 PM Posted Monday at 02:35 PM Hmm, in boot log I see AXP1530 mentioned in theandroid boot (booted off the sd card, not emmc). I attached the log. bootinfo.txt 0 Quote
Randlin Posted Monday at 03:50 PM Posted Monday at 03:50 PM I set the dram speed to 648, no difference. Gotta be the axp or another option. 0 Quote
Nick A Posted Monday at 09:33 PM Posted Monday at 09:33 PM (edited) AXP1530 is the same as AXP313a. Take a look at the link I posted above. You could use this tool to extract your dram settings from an android update or boot0.bin. https://github.com/apritzel/sunxi-fw sunxi-fw info -v boot0.bin Edited Monday at 09:37 PM by Nick A 0 Quote
Randlin Posted Monday at 09:40 PM Posted Monday at 09:40 PM I did notice in the log: INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 0 Quote
Randlin Posted Monday at 09:43 PM Posted Monday at 09:43 PM Wait, that was the Linux kernel, not uboot. I'll get that 0 Quote
Randlin Posted Monday at 10:02 PM Posted Monday at 10:02 PM /sunxi-fw info -v fulldisk.img @ 0: mbr: DOS MBR protective MBR, GPT used GPT version 00010000 usable disk size: 7419 MB number of partition entries: 17 @ 16: toc0: signed boot image 2 items size: 98304 bytes @ 321: toc0: signed boot image 2 items size: 98304 bytes @26812: fit: U-Boot FIT image fit:__overlay__: "<no description>" fit:__overlay__: "<no description>" fit:fragment@2: "<no description>" So I never dumped just boot0 (and no firmware update available), but I have full emmc dump named fulldisk.img. I would assume it is the toc0? Trying to extract does not work , however: (maybe because there are two?) /sunxi-fw extract -v -n toc0 -o uboot0 /home/Tr/fulldisk.img unknown image file extracting the mbr works fine though. 0 Quote
Nick A Posted Monday at 10:17 PM Posted Monday at 10:17 PM This post should help extracting your boot.img from android. That’s if your box is already rooted. 0 Quote
Randlin Posted Monday at 10:26 PM Posted Monday at 10:26 PM (edited) Oh, so it is the devicetree of Linux we want. My bad. Here it is: devicetree.txt FYI I was able to use binwalk -e on the boot partition dump, nice to see there is another way. Thanks for all the help Edited Monday at 10:29 PM by Randlin 0 Quote
Nick A Posted Monday at 10:30 PM Posted Monday at 10:30 PM (edited) Actually in that post it was about downloading the boot_a partition. Then extracting the dts.. you can skip the dts extraction part for now. We need your boot_a partition. also that’s not the android dts you posted. It has some info but not all of it. Edited yesterday at 12:47 AM by Nick A 0 Quote
Randlin Posted 12 hours ago Posted 12 hours ago (edited) Hmm, I used a different boot.img extractor before to try to get dts, but that spectacularly failed ( https://github.com/anestisb/android-unpackbootimg ). I do have a dump of each of the partitions from root, but there was no boot_a boot_b, just boot (not an a/b system). I'll try that extractor, hopefully that will be better. everthing is here: https://archive.org/download/G96_Firmware_Dump/Dumped Partitions/ list of partitions dumped: (there are 17 listed in the emmc, but 18 in android for some reason, probably one is a duplicate) Reserve boot bootloader cache empty env frp media_data metadata misc mmcblk0boot0 mmcblk0boot1 private recovery super vbmeta vbmeta_system vbmeta_vendor Edited 12 hours ago by Randlin 0 Quote
Randlin Posted 12 hours ago Posted 12 hours ago direct link to boot: https://archive.org/download/G96_Firmware_Dump/Dumped Partitions/boot 0 Quote
Randlin Posted 12 hours ago Posted 12 hours ago Ok, that extractor worked. I uploaded it as a zip here: https://uploadnow.io/f/9VvPT91 0 Quote
Nick A Posted 3 hours ago Posted 3 hours ago (edited) Have you tried running sunxi-fw with the boot image you used to extract the dts? The boot image you posted is a U-Boot FIT image. It doesn't have the dram information we are looking for. I believe mmcblk0boot0 is the correct boot image but the one you uploaded didn't work with sunxi-fw. Also, I found this in your dts. Maybe these settings will work. To make sure these settings are correct I prefer to get the dram settings using the sunxi-fw tool. dram { compatible = "allwinner,dram"; clocks = <0xda>; clock-names = "pll_ddr"; dram_clk = <0x288>; dram_type = <0x07>; dram_zq = <0x3f3fdd>; dram_odt_en = <0x9988eeee>; dram_para1 = <0x30fa>; dram_para2 = <0x1000>; dram_mr0 = <0x00>; dram_mr1 = <0xc3>; dram_mr2 = <0x06>; dram_mr3 = <0x01>; dram_tpr0 = <0x00>; dram_tpr1 = <0x00>; dram_tpr2 = <0x00>; dram_tpr3 = <0x00>; dram_tpr4 = <0x00>; dram_tpr5 = <0x00>; dram_tpr6 = <0x2fc08080>; dram_tpr7 = <0x00>; dram_tpr8 = <0x00>; dram_tpr9 = <0x00>; dram_tpr10 = <0x402f3379>; dram_tpr11 = <0xd100b0f>; dram_tpr12 = <0x11131113>; dram_tpr13 = <0x80060>; linux,phandle = <0x183>; phandle = <0x183>; device_type = "dram"; dram_dx_odt = <0x6060606>; dram_dx_dri = <0xd0d0d0d>; dram_ca_dri = <0x1919>; dram_mr4 = <0x00>; dram_mr5 = <0x00>; dram_mr6 = <0x00>; dram_mr11 = <0x00>; dram_mr12 = <0x00>; dram_mr13 = <0x00>; dram_mr14 = <0x00>; dram_mr16 = <0x00>; dram_mr17 = <0x00>; dram_mr22 = <0x00>; }; The dram clock is in hex you'll need to convert this value to decimal. https://www.rapidtables.com/convert/number/hex-to-decimal.html Edited 9 minutes ago by Nick A 0 Quote
