Ducdanh Nguyen Posted Saturday at 09:11 AM Posted Saturday at 09:11 AM i have a allwinner h313 mxq pro 4k 5g, kinda new ig but does anyone have a image than boot and install through microsd card /w adapter (microsd card model : sdhc 16gb) 0 Quote
ARx8 Posted Saturday at 03:13 PM Posted Saturday at 03:13 PM (edited) Hi, @Nick A .I used the repository at https://github.com/armbian/build/to compile (./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm) the image. Except for WiFi and Bluetooth not working properly, everything else runs fine on the SD card. When using ddbr to back up the Android system, it freezes after a few seconds. Using armbian-install also causes it to freeze, and afterward, I can't boot into the Android system anymore. Below is my device's dts. dtb dtb.0 dtb.0.dts dtb.0.dts.yaml Edited Sunday at 02:04 AM by ARx8 0 Quote
Nick A Posted Saturday at 03:21 PM Posted Saturday at 03:21 PM @Randlin there’s a patch for hard coded 1.5 ram detection in the official armbian build. https://github.com/armbian/build/blob/main/patch/u-boot/v2025-sunxi/0009-sunxi-h616-dram-support-1.5GB-RAM-size.patch 0 Quote
ARx8 Posted Sunday at 05:14 AM Posted Sunday at 05:14 AM 14 hours ago, ARx8 said: Hi, @Nick A .I used the repository at https://github.com/armbian/build/to compile (./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm) the image. Except for WiFi and Bluetooth not working properly, everything else runs fine on the SD card. When using ddbr to back up the Android system, it freezes after a few seconds. Using armbian-install also causes it to freeze, and afterward, I can't boot into the Android system anymore. Below is my device's dts. 你好,@Nick A。我使用了 https://github.com/armbian/build 的仓库来编译(./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm)镜像。除了 WiFi 和蓝牙无法正常工作外,其他功能在 SD 卡上运行一切正常。使用 ddbr 备份 Android 系统时,几秒后会卡住。使用 armbian-install 也会导致卡住,之后就无法再进入 Android 系统了。以下是我的设备的 dts 文件。 dtb dtb.0 dtb.0.dts dtb.0.dts.yaml Edited 3 hours ago by ARx8 编辑于 ARx8 @Nick A Thank you 0 Quote
Nick A Posted Sunday at 05:57 PM Posted Sunday at 05:57 PM (edited) @ARx8 can you take a picture of your board so we can figure out if your wifi chip has mainline kernel drivers. You can find the gpio #’s using your dts.0.dts file. The wifi might already be detected but you are missing firmware. If you can post your dmesg. Edited Sunday at 06:01 PM by Nick A 0 Quote
jdie Posted Monday at 01:03 AM Posted Monday at 01:03 AM (edited) Hello, I have x96q2 H313 2/16 board v4.0 ram k4b2g0446c hyh9 and apx305. I tried all img, and no one worked on my TV box. Mb u can help me, how I can build img for my board? I need sd card version armbian or arch Linux (not emmc installation) Edited Monday at 10:19 AM by jdie 0 Quote
ARx8 Posted Monday at 01:39 AM Posted Monday at 01:39 AM (edited) 8 hours ago, Nick A said: @ARx8 can you take a picture of your board so we can figure out if your wifi chip has mainline kernel drivers. You can find the gpio #’s using your dts.0.dts file. The wifi might already be detected but you are missing firmware. If you can post your dmesg. @rafaeldavid My device appears to have the same problem as yours. What was your fix? @Nick AThanks! The chips on the motherboard include H313, AXP313A, KMQN10006B-B318, and EA6521QF (Wi-Fi + BT chip). I have the Linux driver package for this Wi-Fi chip. this Wi-Fi chip (EA6521QF) likely isn't supported by mainline Linux kernel.I’ll figure out how to integrate it later when I need to use Wi-Fi. Using Wi-Fi is not the most important thing; the key is that I want to install it into the eMMC instead of booting from the SD card. May I ask what modifications I need to make to the original Armbian project code based on the dts I provided to ensure stable read/write operations on the eMMC without crashes? Moreover, I've already tried using a different TF card. These same cards work fine when installing to eMMC on my other X96Q (DDR v5.1), but they keep freezing up on this device.。 dmesg.txt Edited Monday at 02:54 AM by ARx8 add dmesg 0 Quote
Randlin Posted 20 hours ago Posted 20 hours ago Unfortunately that patch has not made a significant difference in how far it boots. It does detects 1.5gb in startup now but then detect 2gb later once uboot dts loads and then halts as usual: Spoiler U-Boot SPL 2025.01-armbian-2025.01-S6d41-Pc657-H8869-V004f-Bb703-R448a-dirty (Aug 12 2025 - 15:25:01 +0000) testing 32-bit width, rank = 2 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 10 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 15 rows DRAM:restoring cfg DRAM:end of auto detect dram size DRAM base address is defined as 0x40000000 DRAM has 15 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank DRAM top address must be less than 0x80000000 DRAM top address must be less than 0x60000000 MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 DRAM: 1536 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 20:20:28, Aug 7 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b2520, model: hechuang,x96-q LPDDR3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-Pc657-H8869-V004f-Bb703-R448a-dirty (Aug 12 2025 - 15:25:01 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: hechuang,x96-q LPDDR3 DRAM: 2 GiB (effective 0 Bytes) 0 Quote
Nick A Posted 18 hours ago Posted 18 hours ago (edited) @Randlin Have you tried the latest minimyth2 images? https://github.com/warpme/minimyth2/releases/tag/v14.3.0 maybe you can revert to the old ram size detection. https://github.com/warpme/minimyth2/commit/962ac7da6cb84d0e41826c5555cb101b70a53a8d Edited 16 hours ago by Nick A 0 Quote
Randlin Posted 17 hours ago Posted 17 hours ago Do any of those images use secureboot uboot (toc0) that you know of? 0 Quote
Nick A Posted 17 hours ago Posted 17 hours ago (edited) Oh sorry I forgot… you can add the secure boot patch but compiling minimyth2 might take awhile. or you can copy over minimyth2 latest uboot patches. https://github.com/warpme/minimyth2/tree/master/script/bootloaders/u-boot-aw/files these patches are for uboot version 2025.04. So you need to change the version number here. https://github.com/NickAlilovic/build/blob/v20250306/config/sources/families/include/sunxi64_common.inc declare -g BOOTBRANCH="${BOOTBRANCH:-"tag:v2025.01"}" Edited 16 hours ago by Nick A 0 Quote
Randlin Posted 16 hours ago Posted 16 hours ago I've been doing some research/reading and I see that this was a problem before with a somewhat similar box with 1.5gb ram: I will try copying the patches over, thank you for all your help so far! 0 Quote
Nick A Posted 15 hours ago Posted 15 hours ago (edited) Orange pi zero 3 with 1.5g had the same problem too.. I think they used the 1.5g hardcoded patch to fix it. You might have to remove the newer ram size detection patch. I haven’t updated warpme patches in awhile so I’m hoping this bug has been fixed. Edited 14 hours ago by Nick A 0 Quote
jdie Posted 3 hours ago Posted 3 hours ago (edited) Hello, I tried Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img on my TV box x96q2 H313 2/16 board v4.0 ram k4b2g0446c hyh9, axp305. And I get the message: [60]HELLO! BOOT0 is starting May 13 2020 14:05:42! [65]BOOT0 commit : 593cf83 [68]set pll start [70]periph0 has been enabled [73]set pll end [75]unknow PMU [77]PMU: AXP806 [84]vaild para:8 select dram para0 [87]board init ok [89]DRAM BOOT DRIVE INFO: V0.52 [92]the chip id is 0x5c00 [95]chip id check OK [97]DRAM_VCC set to 1500 mv [100]DRAM CLK =600 MHZ [102]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [108]Actual DRAM SIZE =2048 M [111]DRAM SIZE =2048 MBytes, para1 = 30fb, para2 = 8000000, dram_tpr13 = 6041 [124]DRAM simple test OK. [127]rtc standby flag is 0x0, super standby flag is 0x0 [132]dram size =2048 [134]*****dram handle ok**** [138]card no is 2 [140]sdcard 2 line count 8 [142][mmc]: mmc driver ver 2019-12-19 10:41 [147][mmc]: set f_max to 50M, set f_max_ddr to 50M [152][mmc]: mmc 2 bias 4 [160][mmc]: ***Try MMC card 2*** [191][mmc]: MMC 5.0 [193][mmc]: HSDDR52/DDR50 8 bit [196][mmc]: 50000000 Hz [198][mmc]: 15028 MB [200][mmc]: ***SD/MMC 2 init OK!!!*** [267]Loading boot-pkg Succeed(index=0). [271]Entry_name = u-boot [280]Entry_name = monitor [284]Entry_name = dtb [288]tunning data addr:0x4a0003e8 [291]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-00003-gb6e8ff6-dirty (Jul 21 2020 - 10:23:22 +0800) Allwinner Technology [00.370]CPU: Allwinner Family [00.373]Model: sun50iw9 I2C: ready [00.378]DRAM: 2 GiB [00.381]Relocation Offset is: 75ec5000 [00.423]secure enable bit: 0 [00.425]pmu_axp152_probe pmic_bus_read fail [00.429]PMU: AXP806 [00.433]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.441]drv_disp_init [00.472]__clk_enable: clk is null. [00.478]drv_disp_init finish [00.480]gic: sec monitor mode [00.510]flash init start [00.512]workmode = 0,storage type = 2 [00.515]MMC: 2 [00.517]get mem for descripter OK ! [00.526]get sdc2 sdc_boot0_sup_1v8 fail. [00.530]io is 1.8V [00.574]already at HSSDR52_SDR25 mode [00.577]sunxi flash init ok [00.581]Loading Environment from SUNXI_FLASH... OK [00.591]usb burn from boot delay time 0 weak:otg_phy_config [00.605]usb prepare ok [01.408]overtime [01.412]do_burn_from_boot usb : no usb exist [01.416]boot_gui_init:start FAT: Misaligned buffer address (bbe839d8) 34 bytes read in 4 ms (7.8 KiB/s) [01.546]boot_gui_init:finish [01.549]bmp_name=bootlogo.bmp 3686456 bytes read in 27 ms (130.2 MiB/s) [01.590]hsddr 2-50000000 [01.592]hs200 5-200000000 [01.594]hs400 4-150000000 [01.596]get max-frequency ok 100000000 Hz [01.600]0 0 0: 0 0 0 [01.605]update dts ** Unrecognized filesystem type ** [01.614]load file(ULI/factory/rootwait init.txt) error. ** Unrecognized filesystem type ** [01.626]load file(ULI/factory/snum.txt) error. [01.630]name in map mac ** Unrecognized filesystem type ** [01.640]load file(ULI/factory/wifi_mac.txt) error. ** Unrecognized filesystem type ** [01.652]load file(ULI/factory/bt_mac.txt) error. ** Unrecognized filesystem type ** [01.663]load file(ULI/factory/selinux.txt) error. ** Unrecognized filesystem type ** [01.675]load file(ULI/factory/specialstr.txt) error. [01.685]update part info [boot efex] set misc : boot efex [01.742]mmc exit start [01.800]mmc 2 exit ok [61]HELLO! BOOT0 is starting May 13 2020 14:05:42! [66]BOOT0 commit : 593cf83 [69]set pll start [72]periph0 has been enabled [75]set pll end [76]unknow PMU [78]PMU: AXP806 [85]vaild para:8 select dram para0 [88]board init ok [90]rtc[2] value = 0x5aa5a55a [93]eraly jump fel If i try MiniArch-20240715-6.16.0-board-h313.x96_q-SD-Image.img or MiniMyth2-armv8-master-14.3.0.r502-board-h313.x96_q-SD-Image.img, any version, nothing happens or I get the message "DRAM: DRAM setup is currently not supported". I need SD-card version. But at this point any option will do. Maybe someone has encountered such problems? What are the options for solving the problems of the sicxnull version or miniarch/minimyth2 version? UPD1: When boot android get this message: U-Boot 2018.05-00003-gb6e8ff6-dirty (Jul 21 2020 - 10:23:22 +0800) Allwinner Technology [00.374]CPU: Allwinner Family [00.377]Model: sun50iw9 I2C: ready [00.381]DRAM: 2 GiB [00.384]Relocation Offset is: 75ec5000 [00.426]secure enable bit: 0 [00.428]pmu_axp152_probe pmic_bus_read fail [00.433]PMU: AXP806 [00.436]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.445]drv_disp_init [00.475]__clk_enable: clk is null. [00.481]drv_disp_init finish [00.484]gic: sec monitor mode [00.514]flash init start [00.516]workmode = 0,storage type = 2 [00.520]MMC: 2 [00.521]get mem for descripter OK ! [00.530]get sdc2 sdc_boot0_sup_1v8 fail. [00.535]io is 1.8V [00.578]already at HSSDR52_SDR25 mode [00.582]sunxi flash init ok [00.585]Loading Environment from SUNXI_FLASH... OK [00.595]usb burn from boot delay time 0 weak:otg_phy_config [00.608]usb prepare ok [01.411]overtime [01.415]do_burn_from_boot usb : no usb exist [01.419]boot_gui_init:start FAT: Misaligned buffer address (bbe839d8) 34 bytes read in 4 ms (7.8 KiB/s) [01.549]boot_gui_init:finish [01.552]bmp_name=bootlogo.bmp 3686456 bytes read in 26 ms (135.2 MiB/s) [01.592]hsddr 2-50000000 [01.594]hs200 5-200000000 [01.597]hs400 4-150000000 [01.599]get max-frequency ok 100000000 Hz [01.603]0 0 0: 0 0 0 [01.608]update dts ** Unrecognized filesystem type ** [01.617]load file(ULI/factory/rootwait init.txt) error. ** Unrecognized filesystem type ** [01.629]load file(ULI/factory/snum.txt) error. [01.633]name in map mac ** Unrecognized filesystem type ** [01.643]load file(ULI/factory/wifi_mac.txt) error. ** Unrecognized filesystem type ** [01.654]load file(ULI/factory/bt_mac.txt) error. ** Unrecognized filesystem type ** [01.665]load file(ULI/factory/selinux.txt) error. ** Unrecognized filesystem type ** [01.677]load file(ULI/factory/specialstr.txt) error. [01.687]update part info [01.705]update bootcmd [01.707]No ethernet found. Hit any key to stop autoboot: 0 [01.912]Starting kernel ... [01.915]mmc exit start [01.955]mmc 2 exit ok [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.170 (yxt-rd01@yxtrd01-Super-Server) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Tue Aug 11 11:46:00 CST 2020 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] bootconsole [earlycon0] enabled [ 0.027881] BOOTEVENT: 27.865165: ON [ 0.272767] sunxi_i2c_probe()2209 - [i2c3] warning: failed to get regulator id [ 0.273865] sunxi_i2c_probe()2209 - [i2c5] warning: failed to get regulator id [ 0.329453] acx00_i2c_probe,l:282 [ 0.329625] [ac200] pwm is NULL! Just initialize it. [ 0.330443] [ac200] pwm enable [ 0.330477] [ac200] pwm is initialized [ 0.330570] acx00_init_work,l:130 [ 0.331310] acx00_init_work,l:137 [ 0.331964] sunxi_i2c_do_xfer()1935 - [i2c5] incomplete xfer (status: 0x20, dev addr: 0x10) [ 0.337604] [ac200] get ave_regulator_name failed! [ 0.433136] failed to get standby led pin assign �[ 0.438711] uart uart1: get regulator failed [ 0.472391] [NAND][NE] Not found valid nand node on dts [ 0.481160] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed [ 0.488059] sunxi-wlan soc@03000000:wlan: get gpio power_en failed [ 0.628738] hci: request ohci1-controller gpio:232 [ 0.820154] axp2101_pek: axp2101-pek can not register without irq [ 0.830567] sunxi_ir_startup: get ir protocol failed [ 0.838951] VE: get debugfs_mpp_root is NULL, please check mpp [ 0.838951] [ 0.847219] VE: sunxi ve debug register driver failed! [ 0.847219] [ 0.863567] mmc:failed to get gpios [ 0.941205] mmc:failed to get gpios [ 0.977947] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !! [ 0.985169] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !! [ 0.991622] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed [ 0.999399] [audio-codec]dachpf_cfg configurations missing or invalid. [ 1.006781] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !! [ 1.012748] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !! [ 1.018656] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !! [ 1.024570] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !! [ 1.030494] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:160, pa_ctl_level:0, gpio-spk:0 [ 1.054863] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered [ 1.061670] sndhdmi sndhdmi: snd_soc_register_card() failed: -517 [ 1.071222] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid [ 1.106837] ERROR: pinctrl_get for HDMI2.0 DDC fail [ 1.117004] tv_probe()1435 - of_property_read_string tv_power failed! [ 1.125383] tv_probe()1435 - of_property_read_string tv_power failed! [ 1.206317] cpu cpu1: opp_list_debug_create_link: Failed to create link [ 1.213841] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.221465] cpu cpu2: opp_list_debug_create_link: Failed to create link [ 1.228930] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.236533] cpu cpu3: opp_list_debug_create_link: Failed to create link [ 1.243985] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12) [ 1.720606] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1 [ 1.720606] [ 1.738732] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1 [ 1.738732] [ 2.612742] FAT-fs (mmcblk0p15): bogus number of reserved sectors console:/ $ [ 3.576869] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory [ 23.395613] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR EBE !! [ 23.402157] sunxi-mmc sdc2: send manual stop command failed [ 23.408822] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.415284] sunxi-mmc sdc2: send manual stop command failed [ 23.421941] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.428371] sunxi-mmc sdc2: send manual stop command failed [ 23.434993] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.441482] sunxi-mmc sdc2: send manual stop command failed [ 23.448162] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.454568] sunxi-mmc sdc2: send manual stop command failed [ 23.461302] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.467781] sunxi-mmc sdc2: send manual stop command failed [ 23.474538] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.481019] sunxi-mmc sdc2: send manual stop command failed [ 23.487675] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.494198] sunxi-mmc sdc2: send manual stop command failed [ 23.500841] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.507332] sunxi-mmc sdc2: send manual stop command failed [ 23.514122] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.520545] sunxi-mmc sdc2: send manual stop command failed [ 23.527260] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.533644] sunxi-mmc sdc2: send manual stop command failed [ 23.540345] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.546834] sunxi-mmc sdc2: send manual stop command failed [ 23.553468] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.559989] sunxi-mmc sdc2: send manual stop command failed [ 23.566662] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.573213] sunxi-mmc sdc2: send manual stop command failed [ 23.579913] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.586323] sunxi-mmc sdc2: send manual stop command failed [ 23.593095] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.599558] sunxi-mmc sdc2: send manual stop command failed [ 23.606250] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.612690] sunxi-mmc sdc2: send manual stop command failed [ 23.619407] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.625931] sunxi-mmc sdc2: send manual stop command failed [ 23.632651] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.639072] sunxi-mmc sdc2: send manual stop command failed [ 23.645837] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.652267] sunxi-mmc sdc2: send manual stop command failed [ 23.658998] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.665391] sunxi-mmc sdc2: send manual stop command failed [ 23.672094] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.678624] sunxi-mmc sdc2: send manual stop command failed [ 23.685264] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.691785] sunxi-mmc sdc2: send manual stop command failed [ 23.698528] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.704983] sunxi-mmc sdc2: send manual stop command failed [ 23.711782] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.718228] sunxi-mmc sdc2: send manual stop command failed [ 23.724966] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.731523] sunxi-mmc sdc2: send manual stop command failed [ 23.738173] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.744671] sunxi-mmc sdc2: send manual stop command failed [ 23.751325] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.757815] sunxi-mmc sdc2: send manual stop command failed [ 23.764544] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.770973] sunxi-mmc sdc2: send manual stop command failed [ 23.777730] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.784162] sunxi-mmc sdc2: send manual stop command failed [ 23.790915] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.797446] sunxi-mmc sdc2: send manual stop command failed [ 23.804129] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.810694] sunxi-mmc sdc2: send manual stop command failed [ 23.817380] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !! [ 23.823873] sunxi-mmc sdc2: send manual stop command failed [ 23.830352] sunxi-mmc sdc2: retry:set phase failed or over retry times [ 23.837856] sunxi-mmc sdc2: retry:give up [ 23.842667] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !! [ 23.848689] mmcblk0: error -110 sending status command, retrying [ 23.855588] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !! [ 23.861791] mmcblk0: error -110 sending status command, retrying [ 23.868690] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !! [ 23.874711] mmcblk0: error -110 sending status command, aborting [ 23.881640] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !! [ 23.887737] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !! [ 23.893705] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !! [ 23.899646] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !! [ 23.905557] mmc0: cache flush error -110 [ 34.483900] binder_alloc: 2990: binder_alloc_buf, no vma [ 38.465719] apexd: Can't open /product/apex for reading : No such file or directory [ 40.933841] binder: unexpected work type, 4, not freed [ 59.496340] binder: unexpected work type, 4, not freed [ 73.682650] audit: rate limit exceeded [ 74.543261] binder_alloc: 5395: binder_alloc_buf, no vma [ 75.490661] binder: unexpected work type, 4, not freed Edited 3 hours ago by jdie 0 Quote
jdie Posted 2 hours ago Posted 2 hours ago @Nick A I wonder why android loading stops when the sd card with linux is in the tv box. And when loading the sd card, as I wrote earlier, I see the message "U-Boot SPL 2024.01-armbian-2024.01-S866c-P6135-Ha9af-V6d37-Bda0a-R448a (Sep 19 2024 - 19:48:11 -0400) This DRAM setup is currently not supported. resetting ... ". I am not a super pro user and I don’t know some things. I was looking for the usual answer myself, but after 7 days of searching and popping up I decided to write here. Maybe this will help me in my situation. All the answers I found are for TV boxes v1.3, v5.1 v3.0. No one with v4.0 has seen how I felt about the version and how the boxes and components can differ greatly. 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago (edited) “This DRAM setup is currently not supported. resetting “ You need to extract your boot0 and use sunxi-fw to read your dram settings. sunxi-fw info -v boot0.bin Go back one page. Edited 1 hour ago by Nick A 0 Quote
