ARx8 Posted 2 hours ago Posted 2 hours ago (edited) 3 hours ago, Nick A said: try using the x98h image. @Nick AJust tried, couldn't start with SD. It's worse than before.😔.Currently, it can only run on the SD card using the x96Q-tvbox image. However, writing data to the SD card causes data loss or system crashes. I've already tried almost 10 different models of SD cards. Why is this happening? Have you encountered similar issues before?It usually freezes, and the box's light turns red. Occasionally, it crashes with the error shown in the screenshot. Edited 1 hour ago by ARx8 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago @ARx8X98h has a similar AIC8800D wifi chip. You could probably use the wifi section from x98h dts. I have never had problems with my sdcard. Maybe it’s a bad solder joint? 0 Quote
