Up!
I've forgot device in drawer until now, when my klipper host minipc died..
Got Klipper with CAN and Klipperscreen working great to run my Voron Trident.
Awesome work guys, thanks again!
Posted (edited)
Good evening everyone.
First of all, thank you for this forum and for any help you can provide.
I have an X96Q 2G/16G case with an Allwinner H313 chipset and I'm trying to install Armbian.
I first tested with the MiniArch-20231112-6.6.2-board-h313.x96_q-SD-Image.img image: it boots correctly.
However, when I try with the https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q-v5-1_bookworm_current_6.6.44_mate_desktop.img.xz
the box doesn't boot and the LED remains red.
I'm not an expert in this area; I simply want to install Armbian on this box. If anyone can help me, that would be great.
Thank you in advance for your feedback.
Edited by djoness
Quote
Hi DrEaD.
Thanks for your reply.
I've already tested that version, but unfortunately it doesn't work.
Also, if there's a version without a graphical interface, I'd be interested, as I'd like to use it in server mode, like with Home Assistant.
Thanks.
Posted (edited)
Hi @Nick A
Thanks for your feedback.
I've already tried that version, but it doesn't work either.
The motherboard says BA301_141 V4.1 20244; could that be related to compatibility?
Thanks
Edited by djoness
Posted (edited)
I acquired another X96Q TV Box with the same Armbian-H313 processor, but this time with revision V4.0.
I flashed an SD card with the following image:
Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz
Surprisingly, the box booted correctly with this version.
However, when I tried to install my server, the system prompted me to perform an update.
I ran the following command:
sudo apt update && sudo apt upgrade
After rebooting, the box remained stuck on the red LEDE.
Luckily, I hadn't installed it in the internal memory.
Here is a photo of the two cases:
Here is a photo of the motherboards of both cases:
Here is a photo of the X96Q-Armbian-H313 V4.0 boot screen:
Here is a photo of the X96Q-Armbian-H313 V4.1 boot screen:
Here is the X96Q-Armbian-H313 V4.0 report file:
X96Q-Armbian-H313 V4.0.txt
Here is the X96Q-Armbian-H313 V4.1 report file:
X96Q-Armbian-H313 V4.1.txt
Question:
Could the difference between version V4.0 and V4.1 of X96Q explain the incompatibility during installation?
And how can this be resolved? I would like to use them as servers.
Is there any risk if I reinstall, but this time directly to the case's internal memory?
Thank you in advancur help.
Edited by djoness
Posted (edited)
@djoness you need to Disable Armbian kernel/firmware upgrades using the armbian-config tool. System -> Updates -> UPD002   -  Disable Armbian firmware upgrades -> Disable Armbian kernel/firmware upgrades
  X96Q has many different variations of the same box. Read the bottom of this thread.
https://github.com/warpme/miniarch/issues/102
If you want a well supported box get a Transpeed 8K618-t.
Edited by Nick A
Posted (edited)
I saw that the photos were deleted by mistake, so I added them back.
Here is a photo of the X96Q-Armbian-H313 V4.0 boot screen:X96Q-Armbian-H313V4.0.thumb.jpg.d9752bc337d0e292c2de2803584686a4.jpg
Edited by djoness
Posted (edited)
Did someone managed to make it work on this model below? I tried creating the image with different allwinner chips but its not booting when I burn the sd and insert on the device.
The tv box is a Mortal T1 Android 13 2gb ram and 16gb rom
Edited by JackPipoka
Add another image
Posted (edited)
@ARx8 @rafaeldavid
I was having this problem, and I just figured out that this is a cheat from the chip.
I don't know the details but basically they mark the memory as 2GB but it actually just have 512MB.
The Armbian sees 2GB but when you do a task that requires more that the actual 512MB it crashes.
To solve that I manually set the memory on the Armbian to be 512MB.
Edit the file:
/boot/armbianEnv.txt
Add the line (or change if already exists):
extraargs=mem=512M
On my case the device claimed 2GB of Ram. I reach the 512M testing.
To get to this number I ran:
free -h
This gave me the amount of memory the system was already using (230M).
After that I apt installed memtester and start testing the memory:
memtester 200M
I started at 200M and cancel the test (CTRL-C) on the firsts interaction after:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
The other tests took too long and if the problem is the memory that didnt exist just the firsts test would be enough.
I ran memtester increading by 50M, so 200,250,300... And on 300 the system crashed, so I assumed the real memory of the
chip was 512 (the 230 from the system + the 250 from the memtester before it crashed).
Add info
@djoness I also have V4.0 Box, have same X96Q-Armbian-H313 V4.0 boot screen, so, I burn "Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz" which you said to SD Card, My Box not work.Than i press and hold the Av button,The LED.Show Red,and. Screen Black. nothing. i don't press ,it will be inside to Android.
what are you do, can make inside to Armbian.Tell me.
Thanks a lot.
Quote
Hi @Mayuyu,
I burned the image "Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz" using Balena Etcher onto an SD card, then inserted it into the box and booted normally.
Before that, I had tested the MiniArch-20231112-6.6.2-board-h313.x96_q-SD-Image.img image, and I found that it resolved my boot issue after performing an update.
@djoness Can you share your MiniArch-20231112-6.6.2-board-h313.x96_q-SD-Image.img on Cloud,or Send me email(lq007lq@gmail.com). Because The owner's github update, The old version has been overwritten.
Hi @Nick A,
I seem to have the same x96q v5.1 board as @Trauma.
He reported some time ago that your x98h image runs as intended on the x96q v5.1 board if the following patch is applied:
https://github.com/sicXnull/armbian-build/blob/333e462466670e9a8609771ccd05977b87800881/patch/u-boot/u-boot-sunxi/board_x96q-v5-1/sunxi_mmc-dec-f_max-to-12MHz-to-get-emmc-reliable.patch
Although the v5.1 image from @sicxnull does work as well including ethernet and wifi, I would also prefer the more recent armbian version.
Can you briefly explain the steps necessary to build a corresponding image for the x96q v5.1?
Thank you
Hi @sicxnull @Nick A,
as mentioned by @ventara X96Q vs 5.1 image of sicxnull has direct ethernet port and wireless working fine instead the Nick A 'Armbian-unofficial_25.05.0-trunk_X96q-ddr3-v5-1_bookworm_edge_6.12.11_xfce_desktop.img' has no ethernet or wifi working. I'm totally a newbie on these things, but thanks to the comunity I was able to use an mxq mini (S905X) working with Armbian and home assistant (of course i just used an image with armbian and after I load HA and tailscale. Now I would like to use the X96Q vs 5.1 for the other house. I know that the image of sicxnull works but I prefer to use Nick A. because armbian config as well most of the things are like the one on the other working tv box instead on the sicxnull image there is mate and a lot of commands or gui function are so different. I tried to understand what is different between the two images and github repository to be able to fix almost the ethernet port problem but I do not have enough acknowledge. My unix experience was with the AT&T unix system 5 and Solaris so very old OS and many years ago. Only now I'm coming back to unix world and I don't know anything about git, patch and so on. I read in a post that someone was able applying a patch but it is not clear to me how and where to apply patch, I have already installed Ubuntu in a Virtualbox and prepare everything to compile Armbian and tested that initial script start, ask me for board and other staff but after I stopped because I realized that I didn't understand what I'm doing. Probably with a standard sbc was easier. I promise that I will go ahead studying but it is hard and confused at the moment. If I can do something to help of course when I'm at home I will do it. Please, when you have free time give me some info on how to fix at least the direct ethernet port.
armbianEnv.txt and boot.cmd looks same file. In both dtb folder there are same namefile.dtb include the 5.1 where armbianEnv point out but I don't know if they are same file in both distribution or are different?
Wifi chip is the XR819 like I saw in other image with the v 5,1
Thanks for the great job you and the comunity are doing!
