RSS Bot Posted August 12, 2024 Posted August 12, 2024 Bumps pyyaml from 6.0.1 to 6.0.2. Release notes Sourced from pyyaml's releases. 6.0.2 What's Changed Support for Cython 3.x and Python 3.13. Full Changelog: https://github.com/yaml/pyyaml/compare/6.0.1...6.0.2 6.0.2rc1 Support for extension build with Cython 3.x Support for Python 3.13 Added PyPI wheels for musllinux on aarch64 Changelog Sourced from pyyaml's changelog. 6.0.2 (2024-08-06) yaml/pyyaml#808 -- Support for Cython 3.x and Python 3.13 Commits 41309b0 Release 6.0.2 (#819) dd9f0e1 6.0.2rc1 (#809) f5527a2 disable CI trigger on PR edits b4d80a7 Python 3.12 + musllinux_1_1_x86_64 wheel support See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
