RSS Bot Posted August 13, 2024 Posted August 13, 2024 Description Building for mangopi mq crashes with the following error: Image 'itb' is missing external blobs and is non-functional: opensbi /binman/itb/fit/images/opensbi/opensbi (fw_dynamic.bin): See the documentation for your board. The OpenSBI git repo is at https://github.com/riscv/opensbi.git You may need to build fw_dynamic.bin first and re-build u-boot with OPENSBI=/path/to/fw_dynamic.bin Some images are invalid make: *** [Makefile:1124: .binman_stamp] Error 103 --> (179) ERROR: Error 2 occurred in main shell [ at /armbian/lib/functions/logging/runners.sh:211 run_host_command_logged_raw() --> lib/functions/logging/runners.sh:211 run_host_command_logged_long_running() --> lib/functions/logging/runners.sh:188 do_with_ccache_statistics() --> lib/functions/compilation/ccache.sh:39 compile_uboot_target() --> lib/functions/compilation/uboot.sh:230 loop_over_uboot_targets_and_do() --> lib/functions/compilation/uboot.sh:287 compile_uboot() --> lib/functions/compilation/uboot.sh:391 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_uboot_build_from_sources() --> lib/functions/artifacts/artifact-uboot.sh:175 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:108 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 See, e.g., https://forum.armbian.com/topic/21465-armbian-image-and-build-support-for-risc-v/?do=findComment&comment=190008 The fix is to build OpenSBI and use it to build uboot as suggested in error message, as discussed in https://forum.rvspace.org/t/building-u-boot-from-mainline-repo/3398 for example. This PR adds OpenSBI building stage. How Has This Been Tested? [x] Built for BOARD=mangopi-m28k Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] My changes generate no new warnings View the full article
