Tim Makarios Posted August 15, 2024 Posted August 15, 2024 One of my Armbian machines (24.5.5 bookworm) is running PostgreSQL. I don't think I've changed any of its default settings relating to PostgreSQL's log files or their permissions, but I'm occasionally getting emails from the armbian-truncate-logs cron job saying: Quote truncate: cannot open '/var/log/postgresql/postgresql-15-main.log' for writing: Permission denied The directory /var/log/postgresql is owned by root (and group postgres) and has permissions drwxrwxr-t, and the file /var/log/postgresql/postgresql-15-main.log is owned by postgres (and group adm) and has permissions -rw-r-----. In /var/log.hdd/postgresql the ownership and permissions are the same, and there are also files postgresql-15-main.log.1, postgresql-15-main.log.2.gz, postgresql-15-main.log.3.gz, ..., postgresql-15-main.log.10.gz (with the same ownership and permissions as postgresql-15-main.log). The file postgresql-15-main.log.1 is a prefix of postgresql-15-main.log. I have this problem only with PostgreSQL's logs; armbian-truncate-logs doesn't complain about any other log files. Is there something I need to do to fix this, or is this a bug that will be fixed in future? 0 Quote
Tim Makarios Posted September 13, 2024 Author Posted September 13, 2024 I seem to have successfully worked around this problem by changing the permissions on /var/log/postgresql. I'm not sure why the cron job, which looks like it's set up to run as root, couldn't truncate the file in that folder; and I'm not sure whether my solution is durable, or whether a reboot or something might reset the permissions at some stage, but it works for now. 0 Quote
Tim Makarios Posted November 15, 2024 Author Posted November 15, 2024 It does, indeed, seem to have reverted to the problematic permissions after a reboot. 0 Quote
Wytze van der Raay Posted September 20, 2025 Posted September 20, 2025 As far as I know, the permissions of /var/log/postgresql after a reboot are recreated from those on /var/log.hdd/postgresql. So if you modify those as well (remove the sticky bit), the workaround should be permanent. Thanks for highlighting this problem, I've encountered the very same issue, but didn't realize it was caused by this somewhat peculiar directory permission. So I just applied your workaround (plus my extension) and hope it will fix this once and for all. 0 Quote
Tim Makarios Posted December 11, 2025 Author Posted December 11, 2025 Thanks for the suggestion, but it didn't work for me. Both /var/log/postgresql and /var/log.hdd/postgresql reverted to their pre-intervention ownership and permissions when I rebooted. 0 Quote
