I'm trying to interface an I2C device to Orange Pi Zero with armbian.
By running i2cdetect I obtain the following result:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I've tried to load i2c-dev module but I don't see it in lsmod...
Also after that I've run I2c detect I found a lot of those lines in dmesg:
[   58.110105] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77)
I0ve already checked the script.bin and seems that twi are all enabled.
Can you help me?
Thanks a lot
I also had this result until we changed the order of the cables : SDA / SCL
i2cdetect -y 0
i2cdetect -y 1
Look here:
i2c--smbus-and-armbian-linux
i2c interface on orange pi lite
Orange Pi I2C
orange pi / I2C / LCD 2x16 / internetradio
Lcdproc also works .... but it requires compiling under the driver: hd44780
hd44780.so-Armbian-5.25-Ubuntu-xenial-3.4.11
Or your own compilation according to this howto
https://bbs.nextthing.co/t/lcdproc-with-20-character-by-4-line-lcd/8789
