RSS Bot Posted August 19, 2024 Posted August 19, 2024 Bumps setuptools from 72.1.0 to 72.2.0. Changelog Sourced from setuptools's changelog. v72.2.0 Features pypa/distutils#272pypa/distutils#237pypa/distuils#228#4538) Commits 76942cf Bump version: 72.1.0 → 72.2.0 780a782 Correct reference in news fragment. Ref #4539 64f10c5 Merge pull request #4539 from pypa/feature/distutils-b7ee725f3 d4ad24b Add news fragment. 0ab156c Merge https://github.com/pypa/distutils b7ee725 Apply isort. Ref pypa/distutils#240 32e5fea Rely on monkeysession to monkeypatch. 5f79f22 Merge pull request pypa/distutils#274 from msys2-contrib/ci-msvc-python-mingw... 6748224 Merge pull request pypa/distutils#273 from msys2-contrib/tests-fix-venv_insta... 1f999b9 Remove unused RangeMap Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
