NixiElectra Posted August 22, 2024 Posted August 22, 2024 Hello, I'm using Armbian 24.5.3 Bookworm Minimal / IOT but there is no temperature in motd. When I inspect the normal datasources, it symlink to non-existent folder. 0 Quote
outhud99 Posted August 22, 2024 Posted August 22, 2024 (edited) Came here with the same question I see this was also a question (unresolved) on Rock Pi S: lm-sensors, armbianmonitor -m etc, all the usual methods don't work. EDIT: Found some others investigating similar issue on another board here (again, without any resolution): Edited August 22, 2024 by outhud99 0 Quote
Solution NixiElectra Posted September 15, 2024 Author Solution Posted September 15, 2024 Just to update, with Armbian 24.8.2 Bookworm the temperature is now available. 1 Quote
