[Armbian build PR] - sunxi-6.10: Add armbian patches
Description
  • Add armbian patches from sunxi-6.7
  • Adapt the patch series to the new v6.10.5 kernel version
  • Delete unused patches and add newly extracted patches.
How Has This Been Tested?
  • [x] Build for arm64 & test work on board
 ____  ____  _   __  __  __   _  _
| __ )|  _ \(_) |  \/  |/ /_ | || |
|  _ \| |_) | | | |\/| | '_ \| || |_
| |_) |  __/| | | |  | | (_) |__   _|
|____/|_|   |_| |_|  |_|\___/   |_|
Welcome to Armbian_community 24.8.0-trunk Bookworm with bleeding edge Linux 6.10.5-edge-sunxi64
No end-user support: built from trunk
System load:   2%               Up time:       11 min
Memory usage:  6% of 1.94G      IP:            192.168.100.101
CPU temp:      26°C             Usage of /:    18% of 7.2G
Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
15:14:27  1008 MHz  0.00   5%   0%   0%   0%   3%   0%  23,3 °C  0/7
15:14:33  1008 MHz  0.00   3%   2%   0%   0%   0%   0%  22,8 °C  0/7
15:14:38  1008 MHz  0.00   2%   2%   0%   0%   0%   0%  22,2 °C  0/7
View the full article
