RSS Bot Posted August 23, 2024 Posted August 23, 2024 Description armbian-bsp-cli: fix 10-wifi-disable-powermanagement.rules corrected "iw" path made rule better targeted at wifi devices switched from %k (kernel) to $name variable to better integrate with user-provided rules How Has This Been Tested? [x] Tested new rule with actual wifi devices --> udeavdm test /sys/class/net/wlan0 output: Queued commands: RUN{program} : /usr/sbin/iw dev wlan0 set power_save off Checklist: [x] My code follows the style guidelines of this project [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
