Since the H616 is supposed to be very similar to H313 - try this image that @rafman made. Would be great to know if it works. Just load to SD and see if it boots.
Edited by eibrog
Try this miniarch image. If it boots then you can port over the files needed to boot armbian.
https://github.com/warpme/miniarch
https://github.com/warpme/miniarch/releases/download/v20240916/MiniArch-20240715-6.10.10-board-h616.tanix_tx6s_axp313-SD-Image.img.xz
You should also install a serial console to you UART port. You can see the UART pins (GND, TX0, RX0) top left corner of second picture.
https://linux-sunxi.org/UART
Edited by Nick A
@Nick A I have tried this image, still not work. I have bought ch340 to connect UART port, not working. I guest that UART port is disabled by OEM
2 hours ago, Nick A said:
Your TX0 and RX0 wires need to be crossed over.  TX0 red connects to RX0 and RX0 white connects to TX0.
crossed about TX0 and RX0,  also black screen.
That's more android related. You would have to ask the XDA forums. You could make a backup using Armbian. But you would need to boot Armbian first.
Do you have the correct drivers install on windows for your CH340? Putty should be set to 115200 baud rate. To check if your UART is working try booting into android first. You should see the android u-boot messages. Then try the non secure boot armbian images.
Edited by Nick A
@zcrself
Try also the bellow images:
Use Balena etcher to burn it to SD Card.
1>X96Q (Z1-Q1) Secure Boot : https://easyupload.io/l1v7bu
2> X96Q (Z1-Q1) Non Secure Boot : https://easyupload.io/clf6ny
Please let me know if you can boot.
If both images fail to boot then Use your working box, boot on Android go to play store and download the AIDA64 app
Post here screenshots of CPU, RAM,  OS  ,,, etc
Also try to identify your PMIC chip of your board  e.g  axp313a  (red circle)
The driver of CH340 is ok , because it's ok connecting to other tvbox
I will try it. Thanks a lot for your reply
Hey All - just a FYI - your transpeed (non-secure-boot) image working on the T95Max (H618/4GB/32GB) - no wifi - but not on my list of needs.
Much faster than the Q1 - worth the extra $3 lol
Sorry, specifically, @Nick A - your image from github :)
Edited by eibrog
burned these two imgs using etcher 1.7.9, still  no working. still black screen. UART no show anything
Edited by zcrself
@zcrself
I build 2 server images based on X96-Mate (h616)
Download these both images bellow.
https://easyupload.io/m/4yvmoy
Non Secure Boot Image: Armbian-unofficial_24.11.0-trunk_X96-H616_bookworm_current_6.6.44_non-sec.img.xz
Secure boot Image: Armbian-unofficial_24.11.0-trunk_X96-H616_bookworm_current_6.6.44_sec.img.xz
Your Tv-Box also seems to be similar with H96 Max H616
You can try Android  firmware from bellow link.
https://www.h96tvbox.com/firmware-download/
https://drive.google.com/drive/folders/1IJA6yZQwdKc3i9bQl9xlp5jSACZjTb7h
image name ( H616_user_H96MaxH616_10_20220804.1049.img )
Note: Try android images only to the bricked device, and use your serial adapter (after flashing) to see if any boot info is available.
