zcrself Posted November 23, 2024 Author Posted November 23, 2024 On 11/17/2024 at 2:32 AM, rafman said: I build 2 server images based on X96-Mate (h616) i'm deeply grateful. I will try it @rafman 0 Quote
zcrself Posted November 23, 2024 Author Posted November 23, 2024 On 11/17/2024 at 2:32 AM, rafman said: https://easyupload.io/m/4yvmoy I have tried two imgs which you compiled, still no working and black screen 0 Quote
zcrself Posted November 23, 2024 Author Posted November 23, 2024 (edited) On 11/17/2024 at 2:32 AM, rafman said: image name ( H616_user_H96MaxH616_10_20220804.1049.img ) I flash this image using tools named "PhoneixUSBPro" and "PhoenixSuit". All do be not success. The debug logs is attached as follow PhoneixUSBPro_V4.0.0 PhoenixSuit_V1.19 burn.log Edited November 23, 2024 by zcrself 0 Quote
zcrself Posted November 23, 2024 Author Posted November 23, 2024 @rafman I think that the memory of my tvbox is made by Micron Technology. Because the ID of memory is "5LE77 D9QL" and The storage of 32G is made by Kimtigo Technology 0 Quote
zcrself Posted November 23, 2024 Author Posted November 23, 2024 (edited) @rafman I flash the firmware of T95 into my h616 tvbox. It does be successful. but my tvbos can't boot, I am confused about this。 The successful flashing log is attached t95-rom-to-h616.txt Edited November 23, 2024 by zcrself 0 Quote
rafman Posted November 24, 2024 Posted November 24, 2024 On 11/23/2024 at 9:41 AM, zcrself said: I flash the firmware of T95 into my h616 tvbox. It does be successful. but my tvbos can't boot, I am confused about this。 The successful flashing log is attached Flashing may succeeds but if you don't have serial output at all, this means that the image you flashing is not compatible with your device. FYI: There is a version of TRANSPEED 6k (with H616) you can test 3 different firmware. you can find it here : https://repairalltv.com/transpeed-6k-tv-box-android-10-0-firmware-download-allwinner-h616/ Always Check if you have serial output. 0 Quote
zcrself Posted November 30, 2024 Author Posted November 30, 2024 On 11/25/2024 at 6:08 AM, rafman said: you can find it here : https://repairalltv.com/transpeed-6k-tv-box-android-10-0-firmware-download-allwinner-h616/ @rafman I try the three images, no progress. I think that TRANSPEED IMAGE is not suitable for my TV box 0 Quote
rafman Posted November 30, 2024 Posted November 30, 2024 (edited) 10 hours ago, zcrself said: I try the three images, no progress. I think that TRANSPEED IMAGE is not suitable for my TV box I am really confused with your box, From the firmware information you post (from your working box) your firmware seems to be compatible with EVPAD-5S however this EVPAD-5S device specs is different (H6 - 2GB Ram 16GB ROM) also the sticker on your BOARD shows H6 (!) EVPAD 5S firmware: https://drive.google.com/file/d/1yK50Kko99d1jq_t-nUA1Ua4ZejvMv7xR Your device hardware seems to be compatible with EVPAD-5P (4GB RAM 32GB ROM - H616) EVPAD 5P firmware: https://drive.google.com/file/d/1YjHdFVw0XHMW8_4aVUE3Lpfy52NZ0sSu Also Try this EVPAD 6P firmware: https://drive.google.com/file/d/15v7Ki9Ad6cL-Jr85B8I059VlkeTVA0aE Flash tool https://drive.google.com/file/d/19bIdG3MpAa5yq7k-XfLTKLuGUXEasxMR Try all firmware and Always Check if you have serial output and if you can boot. Edited November 30, 2024 by rafman 0 Quote
k4fari Posted December 7, 2024 Posted December 7, 2024 (edited) @rafman Thanks for the links, I have flashed my Evpad 6p successfully, but now i am unable to find the AI Manager and EVAI Voice Assistant Application to use the built in voice commands. Any help on this issue ? Edited December 7, 2024 by k4fari Apps missing 0 Quote
rafman Posted December 8, 2024 Posted December 8, 2024 On 12/7/2024 at 4:43 AM, k4fari said: Thanks for the links, I have flashed my Evpad 6p successfully, but now i am unable to find the AI Manager and EVAI Voice Assistant Application to use the built in voice commands. Any help on this issue ? Sorry but i can't provide support for android apps, I don't have the time to do this, However You can ask the manufacturer of your box for this kind of problems ( https://www.evpadpro.com ) 0 Quote
k4fari Posted December 10, 2024 Posted December 10, 2024 I contacted them, and they said " sorry we can't help you as you have flashed your device." Is there any tool to be used to extract apk files from a Rom/firmware img? I have searched but couldn't be able to find a working one. 0 Quote
zcrself Posted December 14, 2024 Author Posted December 14, 2024 On 12/1/2024 at 3:10 AM, rafman said: Try all firmware and Always Check if you have serial output and if you can boot. @rafmanAlmost succeeded. The progress reached about 70% evpad5s.txt evpad6p.txt 0 Quote
zcrself Posted December 14, 2024 Author Posted December 14, 2024 (edited) On 12/10/2024 at 1:52 PM, k4fari said: I contacted them, and they said " sorry we can't help you as you have flashed your device." Is there any tool to be used to extract apk files from a Rom/firmware img? Using imgRePacker and simgtoimg to extract apk files from a img Edited December 14, 2024 by zcrself 0 Quote
k4fari Posted December 16, 2024 Posted December 16, 2024 @zcrself thanks for the help, i have flashed the above file shared by the @rafman on my evpad 6p and managed to use the AI Genius and EVAI. I used phoenixsuite to flash, clicked on wipe-all button and after flashing ultimately the evpad 6p tv box mac address turned into 02:00:00:00:00. Searched the Internet and many forums but couldn't be able to find a solution to fix this issue. Any help to fix mac address? 0 Quote
dimitrisxl Posted January 3, 2025 Posted January 3, 2025 Hi friends, we have H96max h616 Android box, and we are trying to upgrade it to Android 11, but we cant... We can not load the firmware "H616_user_H96MaxH616_10_20220804.1049.img" from the official site: https://www.h96tvbox.com/firmware-download/ because it says "Error! Loading firmware failed!" in Factory Tool... Any other idea? What is the best latest firmware for it? Thanks 0 Quote
Warlock Posted January 5, 2025 Posted January 5, 2025 Good day! Please help. Assembly required Armbian for Transpeed 6K on Debian Server 12 or Ubuntu Server 22.04. Chip: H616 PMU: AXP806 RAM: 2Gb ROM: eMMC 32 Gb 0 Quote
noelobo Posted April 18, 2025 Posted April 18, 2025 Hello, zcrself. I have a box that is exactly the same as yours. Unfortunately, I can't find any relevant information about this box across the entire Internet. Could you tell me if your box has been repaired now? 0 Quote
marcos muniz Posted April 19, 2025 Posted April 19, 2025 Hello everyone! Has anyone managed to get Armbian working on one of these boxes? Mine is referenced as H616 - T95 MAX - AXP313A v3 I have burned several images with Win32DiskImage and I can never get the device to boot. I also don't receive any messages via the UART console. Has anyone managed to do this? 0 Quote
zcrself Posted yesterday at 07:03 AM Author Posted yesterday at 07:03 AM (edited) On 4/19/2025 at 6:31 PM, marcos muniz said: Hello! Links is broken... @macros muniz try this: https://www.123865.com/s/96P8Vv-KmR0H Code: cNU2 On 4/18/2025 at 12:11 PM, noelobo said: Hello, zcrself. I have a box that is exactly the same as yours. Unfortunately, I can't find any relevant information about this box across the entire Internet. Could you tell me if your box has been repaired now? No repaired @noelobo On 4/19/2025 at 6:31 PM, marcos muniz said: Hello! Links is broken... try this: https://www.123865.com/s/96P8Vv-KmR0H Code: cNU2 Edited yesterday at 07:05 AM by zcrself 0 Quote
zcrself Posted yesterday at 12:27 PM Author Posted yesterday at 12:27 PM On 11/17/2024 at 2:32 AM, rafman said: image name ( H616_user_H96MaxH616_10_20220804.1049.img ) burn20260208.LOG 0 Quote
zcrself Posted yesterday at 05:05 PM Author Posted yesterday at 05:05 PM On 11/13/2024 at 4:40 AM, rafman said: Also try to identify your PMIC chip of your board e.g axp313a (red circle) @rafman pmic is axp1530 via device info HW app 0 Quote
Nick A Posted 20 hours ago Posted 20 hours ago (edited) @zcrselfhttps://github.com/NickAlilovic/build/releases/tag/Mainline try this image. Edited 20 hours ago by Nick A 0 Quote
zcrself Posted 17 hours ago Author Posted 17 hours ago 3 hours ago, Nick A said: try this image. thanks a lot, I will try it soon 0 Quote
zcrself Posted 15 hours ago Author Posted 15 hours ago (edited) 5 hours ago, Nick A said: try this image. No works, UART output null. I think that UART is disabld by OEM. because a working tvbox , UART also output is null Edited 15 hours ago by zcrself 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago @zcrself Your board might be missing some components for UART to work properly. Have you tested your TTL to USB adaptor on other boards to see if it works? 0 Quote
