[Armbian build PR] - build(deps): bump tj-actions/changed-files from 44 to 45
RSS Bot
Bumps tj-actions/changed-files from 44 to 45.
Release notes
Sourced from tj-actions/changed-files's releases.
v45
Changes in v45.0.0
๐Ÿ”ฅ๐Ÿ”ฅ BREAKING CHANGE ๐Ÿ”ฅ๐Ÿ”ฅ
  • With changes detected using GitHub's API setting output_renamed_files_as_deleted_and_added to true, would now include the previous file name in the list of deleted files instead of the current file name.
What's Changed
New Contributors
Full Changelog: https://github.com/tj-actions/changed-files/compare/v44...v45.0.0
v45.0.0
  • With changes detected using GitHub's API setting output_renamed_files_as_deleted_and_added to true, would now include the previous file name in the list of deleted files.
What's Changed
... (truncated)
Changelog
Sourced from tj-actions/changed-files's changelog.
Changelog
45.0.0 - (2024-08-21)
๐Ÿ› Bug Fixes
  • Update test skip logic to use custom env (#2242) (b4c0974) - (Tonye Jack)
  • Remove unsupported input (#2238) (525aabb) - (Tonye Jack)
  • deps: Update dependency @octokit/rest to v21.0.2 (3ea85a1) - (renovate[bot])
โž• Add
  • Added missing changes and modified dist assets. (598b721) - (GitHub Action)
๐Ÿ“ Rename
  • Renamed Files decomposed into Deleted: previous_filename and Added:filename (#2236)
Co-authored-by: Tonye Jack jtonye@ymail.com (f8034fb) - (Lukas Pfahler)
๐Ÿ”„ Update
  • Updated README.md (#2243)
Co-authored-by: jackton1 17484350+jackton1@users.noreply.github.com Co-authored-by: GitHub Action action@github.com (40853de) - (tj-actions[bot])
  • Update tsconfig.json (88201be) - (Tonye Jack)
๐Ÿ“š Documentation
  • Add Whadup as a contributor for code (#2239) (94b94fe) - (allcontributors[bot])
โš™๏ธ Miscellaneous Tasks
  • Debug env vars (#2241) (246859d) - (Tonye Jack)
  • Conditionally skip certain test for foked prs (#2240) (46a4c02) - (Tonye Jack)
  • deps: Update dependency @types/node to v22.4.2 (25b2562) - (renovate[bot])
  • deps: Update dependency @types/node to v22.4.1 (257f12c) - (renovate[bot])
  • deps: Lock file maintenance (9b7ba7b) - (renovate[bot])
  • deps: Update dependency @types/node to v22.4.0 (50693d8) - (renovate[bot])
  • deps: Update dependency @types/node to v22.3.0 (87d8f94) - (renovate[bot])
  • deps: Update dependency @types/node to v22.2.0 (950331d) - (renovate[bot])
  • deps: Update dependency eslint-plugin-jest to v28.8.0 (ed00b69) - (renovate[bot])
  • deps: Update dependency eslint-plugin-jest to v28.7.0 (9d768c3) - (renovate[bot])
  • deps: Update dependency @types/node to v22.1.0 (6b79c79) - (renovate[bot])
  • deps: Update dependency @types/node to v22.0.3 (99b60a2) - (renovate[bot])
  • deps: Update dependency ts-jest to v29.2.4 (8ae850f) - (renovate[bot])
  • deps: Update dependency @types/node to v22.0.1 (03d95b0) - (renovate[bot])
... (truncated)
Commits
  • 40853de Updated README.md (#2243)
  • 94b94fe docs: add Whadup as a contributor for code (#2239)
  • f8034fb Renamed Files decomposed into Deleted: previous_filename and Added:filename (...
  • b4c0974 fix: update test skip logic to use custom env (#2242)
  • 246859d chore: debug env vars (#2241)
  • 46a4c02 chore: conditionally skip certain test for foked prs (#2240)
  • 525aabb fix: remove unsupported input (#2238)
  • 25b2562 chore(deps): update dependency @types/node to v22.4.2
  • 257f12c chore(deps): update dependency @types/node to v22.4.1
  • 598b721 Added missing changes and modified dist assets.
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
ร—
ร—
