[Armbian build PR] - build(deps): bump rich from 13.7.1 to 13.8.0
Bumps rich from 13.7.1 to 13.8.0.
Release notes
Sourced from rich's releases.
The Thanks for your patience Release
This is a fairly large update. Mostly an accumulation of small fixes and enhancements. Nothing qualifies as a *breaking change (for some definition), but there may be some subtly changes to output. Check below for anything that might affect you!
[13.8.0] - 2024-08-26
Fixed
Changed
  • RichHandler errors and warnings will now use different colors (red and yellow) Textualize/rich#2825
  • Removed the empty line printed in jupyter while using Progress Textualize/rich#2616
  • Running tests in environment with FORCE_COLOR or NO_COLOR environment variables
  • ansi decoder will now strip problematic private escape sequences (like \x1b7) Textualize/rich#3278
  • Tree's ASCII_GUIDES and TREE_GUIDES constants promoted to class attributes
Added
  • Adds a case_sensitive parameter to prompt.Prompt. This determines if the response is treated as case-sensitive. Defaults to True.
  • Added Console.on_broken_pipe Textualize/rich#3468
Changelog
Sourced from rich's changelog.
Fixed
Changed
Added
Commits
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
