RSS Bot Posted August 26, 2024 Posted August 26, 2024 Bumps setuptools from 72.2.0 to 73.0.1. Changelog Sourced from setuptools's changelog. v73.0.1 Bugfixes Remove abc.ABCMeta metaclass from abstract classes. pypa/setuptools#4503 <https://github.com/pypa/setuptools/pull/4503>_ had an unintended consequence of causing potential TypeError: metaclass conflict: the metaclass of a derived class must be a (non-strict) subclass of the metaclasses of all its bases -- by :user:Avasam (#4579) v73.0.0 Features Mark abstract base classes and methods with abc.ABC and abc.abstractmethod -- by :user:Avasam (#4503) Changed the order of type checks in setuptools.command.easy_install.CommandSpec.from_param to support any collections.abc.Iterable of str param -- by :user:Avasam (#4505) Bugfixes Prevent an error in bdist_wheel if compression is set to a str (even if valid) after finalizing options but before running the command. -- by :user:Avasam (#4383) Raises an exception when py_limited_api is used in a build with Py_GIL_DISABLEDpython/cpython#111506#4420) pypa/distutils#284 Deprecations and Removals setuptools is replacing the usages of :pypi:ordered_set with simple instances of dict[Hashable, None]. This is done to remove the extra dependency and it is possible because since Python 3.7, dict maintain insertion order. (#4574) Misc #4534, #4546, #4554, #4559, #4565 Commits ebddeb3 Bump version: 73.0.0 → 73.0.1 18963fb Merge pull request #4580 from Avasam/no-ABCMeta b7ee00d Remove ABCMeta metaclass, keep abstractmethods 477f713 Override distribution attribute type in all distutils-based commands (#4577) 429ac58 Override distribution attribute type in all distutils-based commands 4147b09 Bump version: 72.2.0 → 73.0.0 2ad8c10 Merge pull request #4576 from pypa/bugfix/distutils-284 8afe0c3 Merge pull request #4574 from abravalheri/ordered_set ad611bc Merge https://github.com/pypa/distutils into bugfix/distutils-284 30b7331 Ensure a missing target is still indicated as 'sources are newer' even when t... Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
