Dantes Posted August 30, 2024 Posted August 30, 2024 Dear Community, This might only be with the NanoPI-r6c images, but the SHASUM contains a temporary path which you don't have an thus fails. Since we cannot change the SHASUM because then the ASC would fail, I have a temporary workaround: sed 's,/.*/,,' armbian.img.sha | sha256sum -c In a script you could either 1. CD into the directory of the image 2. Run the SHASUM there 3. Use $OLDPWD to return or correct the SHASUM inline: sha256sum /path/to/file | sed 's,/.*/,,' > armbian.img.sha Dantes 0 Quote
