[Armbian build PR] - build(deps): bump actions/upload-artifact from 4.3.6 to 4.4.0
Bumps actions/upload-artifact from 4.3.6 to 4.4.0.
Release notes
Sourced from actions/upload-artifact's releases.
v4.4.0
Notice: Breaking Changes :warning:
We will no longer include hidden files and folders by default in the upload-artifact action of this version. This reduces the risk that credentials are accidentally uploaded into artifacts. Customers who need to continue to upload these files can use a new option, include-hidden-files, to continue to do so.
See "Notice of upcoming deprecations and breaking changes in GitHub Actions runners" changelog and this issue for more details.
What's Changed
Full Changelog: https://github.com/actions/upload-artifact/compare/v4.3.6...v4.4.0
Commits
  • 5076954 Merge pull request #598 from actions/joshmgross/exclude-hidden-files
  • d52396a Add a warning about enabling include-hidden-files
  • 710f362 Remove "merged" from include-hidden-files input description
  • 3b315f2 npm run release again 🙂
  • 3be2180 Remove another trailing comma
  • 453e8d0 Update glob license
  • 0a398c1 npm run release
  • a0c40cf Update to latest @actions/glob and fix tests
  • acb59e4 lint
  • cb6558b Exclude hidden files by default
  • See full diff in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
