RSS Bot Posted September 2, 2024 Posted September 2, 2024 Bumps setuptools from 73.0.1 to 74.1.0. Changelog Sourced from setuptools's changelog. v74.1.0 Features Added support for defining ext-modules via pyproject.toml (EXPERIMENTAL, may change in future releases). (#4568) Bugfixes Merge with pypa/distutils@3dcdf8567, removing the duplicate vendored copy of packaging. (#4622) Restored setuptools.msvc.Environmentinfo as it is used externally. (#4625) v74.0.0 Features Changed the type of error raised by setuptools.command.easy_install.CommandSpec.from_param on unsupported argument from AttributeError to TypeError -- by :user:Avasam (#4548) Added detection of ARM64 variant of MSVC -- by :user:saschanaz (#4553) Made setuptools.package_index.Credential a typing.NamedTuple -- by :user:Avasam (#4585) Reraise error from setuptools.command.easy_install.auto_chmod instead of nonsensical TypeError: 'Exception' object is not subscriptable -- by :user:Avasam (#4593) Fully typed all collection attributes in pkg_resources -- by :user:Avasam (#4598) Automatically exclude .tox|.nox|.venv directories from sdist. (#4603) Deprecations and Removals Removed the monkeypatching of distutils._msvccompiler. Now all compiler logic is consolidated in distutils. (#4600) Synced with pypa/distutils@58fe058e4, including consolidating Visual Studio 2017 support (#4600, pypa/distutils#289pypa/distutils#287#4606) Misc #4592 Commits 1a9d873 Bump version: 74.0.0 → 74.1.0 4d9a750 Merge pull request #4626 from pypa/bugfix/msvc-EnvironmentInfo a16582b Add a test for construction of EnvironmentInfo. 616d873 Add news fragment. 2423888 Remove only the monkeypatching, leaving EnvironmentInfo in place. 7ecbcb0 Revert "Remove monkeypatching of _msvccompiler." 5d4473e Implement declarative ext-modules in pyproject.toml ("experimental") (#4568) 592d089 Add news fragment 11731e2 Add docs about ext-modules in pyproject.toml bf768e0 Add experimental warning to ext-modules in pyproject.toml Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
